Old 10-24-2005, 06:17 PM   #1
76bonanza
76bonanza's Avatar
fast idle adjust
I need to lower the rpms on my choke this is done by the fast idle screw yes?
I think it is on the passenger side of carb(holly 3310) How do I do it turn in what direction and small amounts or large amounts?
Thanks for any help
1968 c10
lowered 3" 4"
355/Th400 built by Hatfield racing in joplin MO
76bonanza is offline   Reply With Quote
Old 10-24-2005, 09:00 PM   #2
68Stepbed
68Stepbed's Avatar
Re: fast idle adjust
It's pretty tricky. You can use a small flat blade screwdriver. You'll have to look at the screw from the front of the carb between the choke and main body and stick the screwdriver in from behind the choke. I can't remember which way to turn it. Just adjust it while it's cold and the choke is on.
That's the only thing I don't like about Holleys. Could they have made them any harder to get to?
Matt
68 C10 stepside, LS1/700R4, TCI Engineering suspension system
68Stepbed is offline   Reply With Quote
