Watch out for your cornhole !
![]() Join Date: Jun 2003
FS- 1 ton dually rolling chassis....
Complete rolling chassis.
It's the 133 inch wheelbase. Frame is 68 model with all 72 model stuff on it front and rear. Has fresh disc brakes in front with new calipers and pads. Bearings are all good and repacked with fresh grease. Rotors are good. Rear end is 4.10 with fresh brakes too, out of a 72. I pulled the center section out and cleaned everything and put it together with fresh lube. It looked fine inside. Drums are good shape too. All 6 tires are good. Has crappy wheels. Good SM465 trans and bellhousing with factory crossmember. Full driveline from trans to rear end. Located in DFW. Price is 400 bucks. The good disc brake front and dually rear end is worth the price alone. I was driving this truck around till I pulled the sheetmetal and engine off of it.
Re: FS- 1 ton dually rolling chassis....
How much for the burb?
Thanks, Steve |
Is the chassis still for sale and do you have any pics? I live about 50 miles west of DFW and I 've been looking for a 1 ton 4x4 frame.
![]() Join Date: Aug 2001
junkyardjohn 69 1 TON TOW TRUCK // 84 4WD CUCV BLAZER// 85 1 TON 4WD STAKE TRUCK// 86 M1031 5/4 TON 4WD CUCV// ALOT OF OLD TRUCKS FOR ONE OLD MAN TO DRIVE. ![]() LIFE MEMBER OF P.E.T.A (PEOPLE EATING TASTY ANIMALS) DON'T RENT U-HAUL ALWAYS TELL THE TRUTH IT WILL AMAZE PART OF THE PEOPLE & ASTONISH THE REST |
Freedom isn't Free
Where did you get your new brake parts at? I have a one-ton dually chassis that needs rebuilt.
