10-24-2005, 08:58 PM | #1 |
Steel brake lines ? Buy pre-made or build you own ?
Should replace some but not all brake lines on my '70, complete kits run 150+ or so without the rubber ones. I can buy lengths at NAPA for a lot less, but has anyone had luck cutting and the doing the double flares ? I have a single flare setup but maybe should buy a whole new kit, IIRC the last time I did double flares the result wasn't so good, I want to be safe, but that seems like a H of a lot of money to get the premade lines, What do you think - Thanks
1968 C10 307 3spd Long Fleet ------ http://67-72chevytrucks.com/vboard/s...d.php?t=201103 1970 C10 305 Super T10 Long Fleet --- http://67-72chevytrucks.com/vboard/s...d.php?t=202285 1971 C20 383 TH350 Dana Posi ----- http://67-72chevytrucks.com/vboard/s...d.php?t=206894 2001 GMC Sierra 1500 C3 6.0 Last edited by Green Machine; 10-24-2005 at 09:00 PM. |
10-24-2005, 09:21 PM | #2 |
I'm watching you!
Re: Steel brake lines ? Buy pre-made or build you own ?
I got the SS setup from inlinetube.com. It was expensive but well made, I would say probably 98% right. I would buy another setup without hesitation if I had another truck. Plus the SS will last alot longer then the original stuff.
Mike
2012 Chevrolet Silverado 1500 Z71 4WD 1993 Chevrolet C-1500 W/T - Blue - 4.3L V-6, 4 speed auto - Dad's (RIP) 1992 Chevrolet S10 - LS swap project 1968 Chevrolet C-10 longbed fleetside - sold |
10-24-2005, 09:28 PM | #3 |
An American Soldier
I agree with Mike. I got the SS from inlinetube.com also. They are pretty knowledgeable and can even get you the correct lines for power disc brake conversion setups.
Dan dan.brue@us.army.mil |
10-24-2005, 09:30 PM | #4 |
Questionable
also, when should you upgrade? and is there a better route to use with the new lines? my truck hardly has any rust and the lines look great on the outside - but i know how caustic brake fluid is.
is it worthwhile to run new lines? is there some better path to use other than stock?
If I've got anything up for grabs, it'll be here: 7-hole gauge cluster for a 67-72 p/u FREE (link) I can't check the forum daily. If I don't reply to you within 24 hours, drop me a PM! I'm (hopefully) still alive and will reply faster to a PM. |
10-24-2005, 09:38 PM | #5 |
72 BB C30 Super LongHorn
inlinetube.com
Thanx for that lead; I needed that info as I am about to that pointe for doing those! Thanx!!!!!
72 BB C/30 Longhorn Super HO72 No-Spin, #'s matching, Tilt, Tach, AC, AM/FM HO72 build : http://67-72chevytrucks.com/vboard/s...d.php?t=714492 2017 SS |
10-24-2005, 09:40 PM | #6 |
Watch out for your cornhole !
I build my own. Once you know how to double flare, it's a snap.
I can build all new ones for what shipping alone would cost on a prebent sent from a supplier somewhere.
10-24-2005, 09:55 PM | #7 |
And Don't Call Me Shirley
IMO it would depend on what style vehicle I was building. If it's a Street Rod type truck (lotsa aftermarket stuff, chrome, polished stuff, etc.), I'll make my own. But I must tell you it takes a bit of experience and trial & error to make them look nice. For any other style build, I think the factory style stuff looks right. I would challenge anyone anyone to make up a set from scratch that will fit as well as the stock stuff (or Inline, Classic Tube, etc.). BTW, it isn't the brake fluid that hurts them, it's the moisture absorbed by the fluid that booger's them up. Nobody ever stays up on flushing the system like we're supposed to. Just my .02 cents.
Rick Tucker 1969 C20/Custom Camper (the Green Machine)Sold 1970 GMC 4000 COE (future Ramp Truck) 1972 K10 Longbed (restoration begins June 2020) |
10-24-2005, 10:07 PM | #8 |
Oddly enough, I just posted a new set of prebent lines in the parts board. Not sure if that's what you're after.
Personally on my truck the brake lines that are easy to get to (like the rear axle lines) are the ones worth saving some bucks on because I can do that myself even when the truck is fully assembled. However, I just converted from a 1970 non power system to a 1972 power disc setup, and although I could have saved a little money trying to figure out the brake lines, I just went with a kit. Everything was in place, and it just wasn't worth it to me to try and bend all the lines myself, especially with the engine installed. It took only an hour or so to install the entire front end lines, and I didn't have to worry about making dozens of small bends. But like I say, my axle lines I did myself. |
10-24-2005, 10:12 PM | #9 |
67 is sold
My plan is to run the ss set from Inlinetube.com as well (they are local for me anyway)
No experience bending here and I don't want this truck to be my first time
Joe - Formerly 67c10step ------------------------------- 1967 Chevy Stepside - ECE 4/6, fuelcell, 5lug - SOLD gr8lakes - My ebay auctions Click here to order forum apparel :: Click here to become a subscribing member Last edited by Joe67; 10-24-2005 at 10:12 PM. |
10-24-2005, 11:20 PM | #10 | |
BlahBlahBlah
10-25-2005, 07:54 AM | #11 | |
Ed ke6bnl Agua Dulce 70 S.E. Los Angeles 70 Chevy short bed 1948 F3 ford pu 1949 F1 stock V8 flathead 3 on floor 1950 F1 pu street rod 1948 F6 Ford Dually/350sbc no bed stock trans&rear 1972 El Camino 4" chop 1953 Chevy 3100 2b daily driver 1970 SB 4X4 400ci 6in lift |
10-25-2005, 04:41 PM | #12 |
Let me just say this, either way can be frustating.
I kept my original lines and used them as patterns....I knew this ahead of time and removed the originals with care. If you dont have the old ones, for instance, I have added master power brakes to mine and needed to make lines from the *very different* proportioning valve to the frame, I used 3/16 line and bent it up until I was happy..then pretty much used it as a pattern for the 1/4. Bending lines and making them look "factory" is an art, requires patience. IF you go the SST route, the line itself is harder to bend and harder to get "good" ends without the proper tool. Inline tube SST line kits dont include the SST nuts at the end of the tubes (might be an upgrade). I also purchased SST lines from them for a 700R4 and they dont fit well at all (working on modifying the bends at this time) hopefully I can make them work. If you decide to make 37deg fittings on SST line, buy a "GOOD" tool for this or you will be disappointed. One last comment....put the lines in BEFORE you install the motor/trans inner fenders, etc....working from above is much easier than crawling under your truck 1000Times to fit a tube (dont ask how I know this)
71 Chevy C-10 SWB Fleetside RamJet-350/4L60e & Compushift/3.73Posi See it at www.prismnet.com/~grzanich |
10-25-2005, 05:07 PM | #13 |
The LuvShack Garage
I bought a SS kit for my master cyclinder? from Tim Christian, it may have
come from Inline, who knows, fit was almost perfect, & I was very happy with the price I got, I'm to darn lazy to try and make them, just my $.02
Owner/Op: "TN Classic Transport Carriers" The Toy: "Square Vette" 72 Hybrid Blazer Toy Barn: "LuvShack" 40 x 60 x 20 Shop Tow Piggy:"Maddy" 88 Silverado 3500 Hauler: "Feathers" 14 Aluma 8218T |
10-28-2005, 02:07 AM | #14 |
what do u guyst think about the stainless steel brake kit in lmc for like 300 dollars.. i was thinkn about goin that direction but im not sure..
10-28-2005, 10:53 AM | #15 |
I'm watching you!
I don't know about LMC's quality but the inlinetube stuff is under $200, plus i have heard bad things about LMC.
Mike
10-28-2005, 02:59 PM | #16 |
Active Member
I had to replace the brake lines on the rear of my tow truck, 1 ton duelly.
I sent the old lines to Classic Tubing and they made up new SS lines. They fit perfect. Cost $45 plus shipping but it was well worth the money. No grief or aggravation. Nice folks to work with also. Take a look at their website: www.classictube.com. Last edited by 72swbcamo; 10-28-2005 at 03:01 PM. |
10-28-2005, 03:29 PM | #17 |
I'm not sure how well this technique works (haven't tried to do it yet), but here's a how-to on double flaring.
http://classicbroncos.com/brake_line_flaring.shtml |
