Old 10-24-2005, 09:35 PM   #1
RPOZ11
72 BB C30 Super LongHorn
RPOZ11's Avatar
72 3/4 ton rear axle info needed
Ok, some have seen my progress on the parts truck, here is where I am at with it:
Frame nearly stripped; will chem strip and Imron Black when it comes back.
Now on the Rear Axle:
I decided to re-use the 14-Bolt Corp Axle, just cause I already have it.
I am taking it in to be rebuilt/resealed, etc...
My questions are:
1:someone else did the shock brackets; what is the correct location for these based off of the pinion location for each side?
2:Where can I get replacement U-Bolts?
3: Where can I buy one 3/4 leaf spring? One side was broken!
I will post pics of what it currently has, and could someone assist me so I can correct them if need be!
72 BB C/30 Longhorn Super
HO72 No-Spin, #'s matching, Tilt, Tach, AC, AM/FM
HO72 build :
http://67-72chevytrucks.com/vboard/s...d.php?t=714492
2017 SS
RPOZ11 is offline   Reply With Quote
Old 10-24-2005, 11:28 PM   #2
Re: 72 3/4 ton rear axle info needed
A spring shop for the u-bolts and leaf.You could get your leaf packs re-arched.I`d suggest replacing the opposing leaf,too.
