Old 10-24-2005, 09:59 PM   #1
BowTieMan
BowTieMan's Avatar
Gear Ratio
Are there any number stamped on my axle in my 70 half ton 12 bolt that can tell me my gear ratio?
"A true hotrodder wouldn't be content untill he had created a car so violent, so hairy, so totally sick that the very act of dropping the hammer would result in instant death. Anything less results in the need to go faster." - Tony DeFeo
BowTieMan is offline   Reply With Quote
Old 10-24-2005, 10:18 PM   #2
Longhorn Man
its all about the +6 inches
Longhorn Man's Avatar
Re: Gear Ratio
why not drain the 10+ year old oil (if not 35 year old) and count the teeth while you are in there?
Old 10-24-2005, 10:33 PM   #3
BowTieMan
BowTieMan's Avatar
Re: Gear Ratio
I am going to be doing that soon. But I wasn't sure if there was a simpler way that I could see now. I am going to do the oil this weekend.
Old 10-24-2005, 10:40 PM   #4
al's71gmc
4 eyed fever
al's71gmc's Avatar
Re: Gear Ratio
The ratio numbers will be stamped on the ring gear. 4 digit #. divide the little # into the big #. You can also jack up the rear of the truck, spin the wheel and count the revs of the driveline. that will get you close, without pulling the cover.
Edit-If it has an optional set of gears in it, it will tell you on the glove box sticker.
1971 GMC 2500 4x4
1972 GMC Sierra Grande 1/2 t 4x4-#1 son's truck. Recently completed resto.
4 YO daughter," Daddy, I like your truck better than Mom's." (2000 F350-ranch truck) Smart kid!!
al's71gmc is offline   Reply With Quote
Old 10-24-2005, 11:15 PM   #5
Re: Gear Ratio
No tab on a cover bolt?I always do the spin and count.The ratios are around 1/3 of a turn apart,it`s obvious what you have.A little more than 3=3.08,about 3 1/2=3.40,a little less than 4=3.73,a little more than 4=4.10,etc.
Old 10-25-2005, 12:07 AM   #6
Longhorn Man
Re: Gear Ratio
what engine/tranny combo did it come with...and was there a gear option listed?
Old 10-25-2005, 01:09 AM   #7
BowTieMan
BowTieMan's Avatar
Re: Gear Ratio
350 engine and th350 trans, and no I didn't see any option other then a limited slip.
I know on my uncles f-250 it is stamped on the housing. Wasn't sure if chevy did that too back then.
I'll just pull the cover and see this weekend. How much is the new gasket and the fluid?
Old 10-25-2005, 06:57 AM   #8
Blazer1970
Blazer1970's Avatar
Re: Gear Ratio
If it came with a 350, it has 3.07 gears unless an optional ratio is listed on the sticker.
Blazer1970 is offline   Reply With Quote
Old 10-25-2005, 01:10 PM   #9
72str8flush
72str8flush's Avatar
Re: Gear Ratio
As an alternative, here is how I figured my gear ratio, which is only good if you have a Tach.
http://www.chevelles.com/shop/ratios.html
72 Chevy Short Bed Fleet: 350/TH350 - Sold - Now trying to sell the parts that I have left over.
_______________________
2006 VW GTI
72str8flush is offline   Reply With Quote
Old 10-25-2005, 02:24 PM   #10
patrolman808
patrolman808's Avatar
Re: Gear Ratio
What would a truck with the 250/3spd possibly have in it? Never pulled my cover to count the teeth. But it was really low geared with the 350/350 I put in it about 10 yrs ago.
70 C10 Stepside, '68 Front clip. No motor/tranny.
69 Firebird LS1/6spd project(sold)
01 Trans Am WS6,red/black,A4, 17x9.5 L.G. Motorsports G2 wheels 275s/315s, DirectFlow lid,QTP cutout.
patrolman808 is offline   Reply With Quote
Old 10-25-2005, 07:45 PM   #11
Longhorn Man
Re: Gear Ratio
the 3.07 gear came with small block and automatic...either manual tranny would net you a 3.73.
The inline with 3 speed...also a 3.73.
