Old 10-25-2005, 06:24 PM   #1
85chevy
Backfire issues
I just put a new engine in my truck. I am getting a sporadic pop at idle and worse as the engine revs up. Someone said it could be the rockers out of adjustment, while others think it is the carb or spark plug wires. The pop is coming out of the exhaust. I am not sure which way to proceed. The engine ran fine when we broke it in 2 weeks ago, but started this last weekend. Anyone have any ideas?
85chevy is offline   Reply With Quote
Old 10-25-2005, 06:40 PM   #2
Rud's 69-C10
Rud's 69-C10's Avatar
Re: Backfire issues
Seems simple enough.
1. check your plug wires vs firing order
2. IF they rocker arm/s did back off, you should be able to detect which cyclinder it is by sound-instead of pulling off both valve covers.
2a. Your're gonna need to replace the rocker arm nut.
Keep us updated
-Rudi-
'69 C10 Fleetside
'69 Camaro (2nd Owner since 1978)
'86 Bronco 4x4
'86 Ranger 4x4
Rud's 69-C10 is offline   Reply With Quote
Old 10-25-2005, 07:12 PM   #3
85chevy
Re: Backfire issues
The firing order is good, as is the timing. I guess I will have to check the rockers this weekend.
Old 10-25-2005, 08:14 PM   #4
sixty8c10
MY EX DRIVES A BROOM
sixty8c10's Avatar
Re: Backfire issues
if you have a rocker thats just a hair to tight it will pop but you won't really be able to hear it in the engine compartment....atleast not like the normal valve rattle when they are loose anyway
They say nobody's perfect.
I'm a nobody, so I must be perfect.
Building Nemo -1968 C10 Long Bed
FRED -1947 KB-2 International
sixty8c10 is offline   Reply With Quote
Old 10-25-2005, 09:49 PM   #5
Nolowrider
Nolowrider's Avatar
Re: Backfire issues
I tend to think it is a valve issue. I would check the rockers first, may also be a sticky valve.
Nolowrider is offline   Reply With Quote
Old 10-25-2005, 09:55 PM   #6
us111
Re: Backfire issues
if it ran good at break in i would bet on a rocker arm issue,,.
us111 is offline   Reply With Quote
