Old 10-25-2005, 10:40 PM   #1
mx jim
4x4 12 bolt rear end, same as 2wd rear end???
I Have a 70 chevy 4x4 with 12 bolt and 4:10s. I wanted to get a new rear end because mine is going bad, but i was woundering if the rear end out of a 2wd is the same as the rear end out of the 4x4?? Also can i get a 5 lug rear end and take the axels out and put my six lug axels in it? Thanks for all the help james
mxjim 1970 chevy 4x4, 400 small block, 4" pro comp lift, with 35s.
mx jim is offline   Reply With Quote
Old 10-26-2005, 05:09 PM   #2
b454rat
Re: 4x4 12 bolt rear end, same as 2wd rear end???
The rear out of the same year 2wd won't work, as they have coils instead of leaves. But you could weld some perches on it, and the axle shafts will interchange.
2000 GMC CCSB 454/4L80 6” lift SAS
1999 Chevy CCSB 454/NV4500 4” SAS
1999 GMC Yukon 350/4L60 6" SAS
Old 10-26-2005, 06:04 PM   #3
BIGCHEVYMAN
BIGCHEVYMAN's Avatar
yes you can take the 5 lug axels out and put your six lug axels in. the internals are the same. pay attention to the brake backing plates, you may need to change those also.
BIGCHEVYMAN is offline   Reply With Quote
Old 10-26-2005, 11:23 PM   #4
mx jim
Thanks for the info. Ya i don't mind making the rear end fit. I have welders and mills and laiths, so making it fit is no problem. its just finding on with 4:10s and the right price. The rear end that is in the truck now is out of a 76 truck wich i had to cut the brackets to make it fit. THANKS
Old 10-27-2005, 12:49 PM   #5
Americanrider
Try shopping on Pirate 4x4 boards, be sure to post your width of spring perches and ratio needed. They have a large member base in Cali and everyone there wants to unload 1/2 ton stuff cheap. They are all into 3/4 and 1 tons for trails & rocks. Good Luck!
Americanrider is offline   Reply With Quote
