10-26-2005, 06:58 PM | #1 |
Windshield install.
what would be the best way.
have some one do it. or get the glass an do it my self.talked to a install place and they ssaid they dont want to do it cuase the last one took them 4hrs ....sounds to long to me. but are there critical steps to this that would require a professional or can i do it my self? they said they can get me the glass but wont install. will cost 120. for the glass. pluss the gasket an any goop i get to seal it. what ya'll thank? this will get me onestep closer. ..want to get it done next week. thanx. w. |
10-26-2005, 07:22 PM | #2 |
Re: Windshield install.
i'd get an pro to install it its hard work to do but 4 hours is too long to me
10-26-2005, 07:33 PM | #3 |
Junior Member
i did mine in 20 minutes with my son .used new glass and new rubber.but if you have chrome trim install it first
10-26-2005, 07:34 PM | #4 |
I put one in my 67 with the rope trick around the seal. It was a pain but it did not take 4 hours though. It was my first time doing it and it turned out well (for $120.00 I would do it again myself). If you have the type that has the trim around it it might be different, anyone else done one with the trim?
67 short wide 355ci 3 on tree 69 short wide 250ci 3 on tree 68 long wide 283 3 on tree 72 2wd Blazer project 454 5 speed |
10-26-2005, 07:47 PM | #5 |
member #16
There is a windshield install thread in FAQ that explains it very well. Good luck Here it is John
http://67-72chevytrucks.com/vboard/s...ad.php?t=90510
john http://67-72chevytrucks.com/vboard/showgroups.php board vendors http://www.flickr.com/photos/1745471...7602865984234/ Last edited by john; 10-26-2005 at 07:51 PM. |
10-26-2005, 08:23 PM | #6 |
I have installed tens of dozens of windshields, I use weed eater line...Works awesome with windex. Use plenty of windex and it will help to have a buddy over for a few beers to help. Whatever you do...DO NOT pound the corners when you are trying to get it to go in UNLESS it is to just seal it. If the rubber has not quite made it in and you hit the corners CARACK! Just be patient and you'll be fine, remember windex.
I always start/finish in the top center. Make sure to overlap the line/rope to insure you pull all of the rubber inside. Have your buddy apply a consistant pressure as he follows you pulling the cord, try and have him about 6 inches behind or it makes it bind too easily. The whole process should not take longer than about 20-30 minutes like fine 67 said, it is a simple process. If you have the chrome trim, it may take a bit longer because the chrome needs to go on the rubber (once you have it on the glass) before you install the windshield. Hope that was not too much information and or made sense. Good luck, Mike. P.S. I bought my tinted and shaded windshield from Classic Industries for $99 and is awesome (I bought the tinted rear window as well), shop around a bit to find a good price. Last edited by BigMike; 10-26-2005 at 08:24 PM. |
10-26-2005, 08:29 PM | #7 |
cool ill check out the classic industries place..and the FAQ...i didnt think this was a hard project...
10-26-2005, 11:43 PM | #8 |
Car O'Holic
I did the whole do it yourself route and the back window came out PERFECT but I cracked the front so.... I would take the front to a pro
10-27-2005, 06:17 AM | #9 |
Watch out for your cornhole !
I just put one in yesterday. It took me about 30 minutes.
A trick, don't use spray windex for lube, use ZGoop handcleaner. It will stay put and not run off.
10-27-2005, 06:40 AM | #10 |
I'm scared to death to try. I had a professional come out and try it, and he worked for over an hour and just couldn't get it to go in. Now what? Used glass and new rubber, but still no windshield installed. Cab is straight, not warped.
Is it the same windshield for 67 thru 72? Same rubber for all 6 years?
1968 Custom SWB, 327/3 speed OTC 1969 CST LWB, 402/400 1970 CST LWB, 402/400 1970 Sierra Grande LWB, 350/350 1971 Cheyenne LWB, 350/350 1972 Cheyenne Super LWB, 402/400 1972 Sierra Grande LWB, 402/400 1979 Silverado LWB, 350/350 1984 Suburban 1990 454 SS 1991 Silverado, X-cab, 4.3/5 speed Getrag 2005 Silverado Crew Cab Corvettes: 75, 77, 78, 93, 96 Last edited by 73737373; 10-27-2005 at 06:41 AM. |
10-27-2005, 09:26 AM | #11 |
It's no rocket science. The same windshield fits 67-72, same rubber to.
I never had any formal training installing glass, I just do it. Use the cord like the guys suggested, lube the rubber thoroughly, and go to it. Use a pick tool to finish pulling the flap all the way in.
10-27-2005, 11:29 AM | #12 |
The rubber can be different if you have the trim. There is shallow and deep groove.
I had an impossible time with mine... simply refused to go in. Changed out the glass for PPG and it almost installed itself. It might also help to grind down and clean up any protrusions around the frame.
71 Blazer / GMPP ZZ383 / MPFI / 700R4 / 4-Wheel Disk / Ground-up frame off almost completed resto-mod |
