Old 10-26-2005, 09:04 PM   #1
AKChevyman
Chevy Forever
AKChevyman's Avatar
Exhaust routing on lowered trucks?
Ok I have a few question I am not quite there yet but I am curious on how you guys routed your exhaust I need examples I am running airbags and I will need room for the tank and pumps later but I want to run dual 3" for the Big block that is going in the front. I don't plan on changing the cross member that the trailing arms attach too either. Any help you guys can provided will be helpful Oh also I don't plan on going past the rear axle with it becuase I am running a custom fuel tank at the rear of the truck. SO the pipes will dump right in front of the rear wheels. so I guess my main question is do I stay in the frame or go out side right from the get go. as always any advise is good advise thank you.
My first love
1971 C20
Hugger orange
Getting face lift and heart transplant .30 402 BB /TH400 and GV
Wifes car
1969 Chevelle SS 396 325hp/TH400
Factroy A/C Automatic w/ Floor shift console.
restored.
AKChevyman is offline   Reply With Quote
Old 10-28-2005, 01:39 PM   #2
7deuce
Sold! 2 days after finished
7deuce's Avatar
Re: Exhaust routing on lowered trucks?
You can either spend $350 on a EEC X member or take a torch and cut a big hole on both side of the X member. If you want to get fancy cut some 4 inch pipe and weld it in, thats what I did.
7deuce is offline   Reply With Quote
Old 10-28-2005, 01:44 PM   #3
Joe67
67 is sold
Cutting holes has been a common recommended method on the board. More then likely the way I will end up going
Joe - Formerly 67c10step
1967 Chevy Stepside - ECE 4/6, fuelcell, 5lug - SOLD
gr8lakes - My ebay auctions
Click here to order forum apparel :: Click here to become a subscribing member
Joe67 is offline   Reply With Quote
Old 10-28-2005, 01:53 PM   #4
67Fleet
Outlandish Trends - FL
67Fleet's Avatar
Me too. Mine are routed under the crossmember now and after the front end comes down another 1-1/2 - 2" this weekend I'm thinking I'm gonna have some issues....
-Bret
67 short-fleet sold!
67Fleet is offline   Reply With Quote
Old 10-28-2005, 02:25 PM   #5
Frizzle Fry
Frizzle Fry's Avatar
If it goes through the crossmember it still has to drop below the frame to come out before the rear tires right? Here's what I did, but my headers hang kinda low to begin with.
Frizzle Fry is offline   Reply With Quote
Old 10-28-2005, 02:35 PM   #6
dennislbrooks
dennislbrooks's Avatar
7deuce, please post pic.
dennislbrooks is offline   Reply With Quote
Old 10-28-2005, 02:37 PM   #7
67Fleet
67Fleet's Avatar
Looks great Frizzle! Yeah, long tubes are out of the question for me. They wouldn't last very long with all these horrible FL roads.
-Bret
Old 10-28-2005, 04:40 PM   #8
layed67chevy
layed67chevy's Avatar
when i lay mine out i'm sitting on my headers so i'm gonna have to go with some shorty headers or reg manifolds.....it all depends on how low you want to go
layed67chevy is offline   Reply With Quote
Old 10-29-2005, 07:40 PM   #9
AKChevyman
Chevy Forever
AKChevyman's Avatar
Well I don't plan on going low but I guess I will have the option since I have 3" drop spindles and running bags so I can run what ever fits I guess ;o) But really I only want it low enough to even it out or some thing around the lines of 4/6 for the drop do you think that will be too low to run full length headers like Fizzle. I like the look of a 4/6 drop but if that is too low I will have to go higher.
My first love
1971 C20
Hugger orange
Wifes car
restored.
Old 10-30-2005, 04:46 PM   #10
Tx Firefighter
Watch out for your cornhole !
Tx Firefighter's Avatar
I've run both Hooker Comp and Dynomax full length headers on 4/6 dropped trucks. Neither were an issue with hanging too low. These were small block applications though.
Old 10-30-2005, 05:27 PM   #11
Frizzle Fry
I don't know exactly what my drop is because my set up is a mixed bag. 2.5" spindles with cut small block springs and a 396. I have at least 2.5" maybe 3" blocks in the back (custom made by me about 10 years ago). I'll have to measure. I think the rear springs are saggin on top of that so take your best guess at what drop I have... Anyway, the exhaust rarely scrapes over LARGE bumps and it is a 127" wheelbase.
Old 10-30-2005, 05:38 PM   #12
Tx Firefighter
Frizzle, are those 255/50/17's on your Suburban?
Old 10-30-2005, 06:20 PM   #13
SCOTI
SCOTI's Avatar
That's what I had done for my RestRod.
First, we completely boxed the crossmember to make the structure stronger. Then we opened up the drive-shaft hole for more clearance @ the top, cut the holes for the 4" dia pipe, & welded them in. We also welded the trailing arm mounts on the outside of the brackets for added insurance (mine's a big block too). My exhaust consists of Sanderson 3/4 length Chevelle headers & 3" mandrel exhaust the dumps just in front of the rear-end. You can't see the exhaust system from the side of the truck (it does not hang below the frame).
Now I'm re-engineering it all & purchased an ECE c-member because I want more ground clearance & I hope to be able to snake that 3" exhaust all the way back to the rear corner of the bedsides/bumper area. I'm raising the bed-floor to accomplish the exhaust (there's not enough room otherwise).
67SWB-B.B.RetroRod
64SWB-Recycle
89CCDually-Driver/Tow Truck
99CCSWB Driver
All Fleetsides
@rattlecankustoms in IG
Old 10-30-2005, 06:30 PM   #14
Frizzle Fry
Pretty darn close Tx: They're 255/45/17s and 275/40/17s. The pic in this thread has those, the pics in my sig link are the old ones which I think were 255/45/17's all around if I remember correctly. Time to post some new pics
Old 10-30-2005, 06:35 PM   #15
Frizzle Fry
Any pics of your current set-up?
Old 10-30-2005, 10:18 PM   #16
SCOTI
SCOTI's Avatar
Unfortunately, no pics @ this time.
I have the bed partially disassembled though so I'll see if I cant get some. I'm assuming you want shots of the exhaust routing as it goes through the crossmember?
67SWB-B.B.RetroRod
64SWB-Recycle
99CCSWB Driver
All Fleetsides
Old 10-30-2005, 10:27 PM   #17
Frizzle Fry
Ya, that and the mods to the xmember itself. Just curious because I think an ECE version might be in my future depending on how low I end up going.
Old 10-30-2005, 11:55 PM   #18
SCOTI
SCOTI's Avatar
Yeah, mine was done years ago (94-95) & just doesn't have the same 'engineered' look like the ECE c-member. The worst part of mine is the factory c-member has that 'dip' that sits below the framerails. I want to get rid of that & the ECE c-member does it for me.
67SWB-B.B.RetroRod
64SWB-Recycle
99CCSWB Driver
All Fleetsides
Old 10-31-2005, 05:27 PM   #19
XXL
Seņor Member
XXL's Avatar
If your response is to AKChevyman, with a 3" spindle and bags, his ride height is going to be somewhere in the 5-6" drop range... so once he dumps the bags, he's going to be way beyond the 4/6 point you're describing.
XXL is offline   Reply With Quote
Old 11-01-2005, 12:02 PM   #20
AKChevyman
Chevy Forever
AKChevyman's Avatar
Thank you all for the great inputs and XXL I don't plan on ever running my bags empty I don't want to lay out at all I am just running the bags for ride quality and to have the flexability to tow a trailer if I still need too. I am only looking for a 4/6 drop ride height and if that won't have enough room for headers then I guess I will make it a 3/5 drop but I will have option with airbags ;o) I think please let me know if I am wrong.
My first love
1971 C20
Hugger orange
Wifes car
restored.
Old 11-01-2005, 12:17 PM   #21
Bowtiefreak
Bowtiefreak's Avatar
A little off topic but I see that ECE is running a sale on their extreme crossmember.
1968 Chevy C10 Short Fleetside/Wood floor
ECE 4-6 Drop / 406 Small Block
1971 Chevelle 427 Big Block
Bowtiefreak is offline   Reply With Quote
Old 11-01-2005, 12:27 PM   #22
67Fleet
67Fleet's Avatar
If those thoughts are real and true, then I sincerely suggest that you go with a static 3/5 or 4/6 drop and then get helper bags for the rear to assist when you need to tow something. Airlift, ECE, and McGaughy's all make quality helper systems that you should consider. The options are out there, but there's no reason to spend a ton of money when you don't need to. A static lowering kit when done right will ride almost or as good as bags, you just won't be able to adjust your ride height all the time. But the helper kit out back will be great for hauling or towing when you need it.
-Bret
Old 11-01-2005, 10:23 PM   #23
SCOTI
SCOTI's Avatar
Or compromise like I did w/my 68 Beater. Up front I did 3" spindles + 1 coil cut from the stock springs & added a 1.25" HD 1-ton 73-up sway-bar. For the rear I installed dbl convoluted style bags (Firestones) & 2" blocks. I relocated my shocks, did the bolt-in c-sections & added an adjustable pan-hard bar to align it all up.
It has towed my 74 in my avatar on my 18ft car hauler w/o any issues.
67SWB-B.B.RetroRod
64SWB-Recycle
99CCSWB Driver
All Fleetsides
Old 11-03-2005, 12:46 AM   #24
confucius_Sez
confucius_Sez's Avatar
anyone know what the stock height of an '86 2wd c10 front coil would be? or are the ends of the coil upposed tobe a rough cut? or smooth? mine look like they were cut with a plasma cutter or a titanium toofed dog chewed them off...maybe that would explain my inside of the tires to be worn down prematurely....and why i have 7-8 shims per each upper control arm...
1986 SWB Silverado red/blue int
'84 305 H.O. (POS) TH400 (looking for 700R4)
2002 Yamaha RoadStar Warrior 1700cc Indigo BLue
Moly: Valley BullDog 1/2 boxer, 1/2 bulldog, all charm.
confucius_Sez is offline   Reply With Quote
Old 11-03-2005, 09:29 PM   #25
XXL
Seņor Member
XXL's Avatar
I don't know the height, but the bottom loop will have a square cut that's pretty clean and the top loop will also be cut square, but be rolled in such a way as to wind up nice and tight next to the coil below it.
Something like this...
