Old 10-26-2005, 10:55 PM   #1
andrew king
1986 suburban auto hub questions please help
I have the factory auto hubs on my burb and just purchased a set of warn manual hubs for it and I cant get them installed. They fit but the snap ring wont go into place is there something Im doing wrong ? Is there a kit for installing them? The hubs werent new but came of exact same front end. ALso anybody have one auto hub thats good out there that they wnat to part with???? please Pm me thanks
andrew king is offline   Reply With Quote
Old 10-26-2005, 11:07 PM   #2
kwmech
Re: 1986 suburban auto hub questions please help
you should be able to put the large diameter snap ring in, but on some of the mid 80s trucks the smaller ring that goes on the axle shaft itself would not fit because the ring groove was not on the outerpart of the shaft (about 1/4- 3/8" off). It can be left off as long as the larger wire ring is in place to hold the locking hub into the wheel hub.
Old 10-27-2005, 09:05 AM   #3
Did you try prying at the u-joint yokes to force the axle stub outward to help get the snal ring in?It can be tough sometimes.
Old 10-27-2005, 06:26 PM   #4
Smokin85
some mid 80s had a snap ring on the axle with a washer behind it that can be left out
Smokin85 is offline   Reply With Quote
Old 10-28-2005, 12:54 AM   #5
blaserman
blaserman's Avatar
Try what Special-K said. I had to do that for my 86 Blazer and it worked just fine.
This is my best friend
blaserman is offline   Reply With Quote
Old 10-28-2005, 05:29 AM   #6
JIMs70GMC
user # 2756
JIMs70GMC's Avatar
smokin 85 is right, my 85 K5 had a washer also that need to be removed when I removed auto hubs and went manual.
1970 K25, 8' stepside bed 350/465/205 44 up front, 60 in the rear 4.10s rolling on 33" Dunlop MTs
1986 K5, 350/465/208 Dana 60/14 bolt from a cucv 36" Super Swampers TSL/SX
1983 K20 w/ CUCV axles, 350/700R4/208 sitting on 37" Goodyears
1986 M1031 6.2 diesel, TH400/NP205 locker in the rear and a LS in the front, all stock for now.....
1986 K30, 350/400/205 dana 60 and 14 bolt. I kept the drivetrain. Body/bad and chassis are gone.
1981 K30, 350/465/205 dana 60 and dually 14 bolt. Has a G80, and a flat bed. Going to replace the flat bed.
1985 K20, 350/400/208 10 bolt and SF 14 bolt. I wonder where I can find some 1 tons. Hmmmmm
JIMs70GMC is offline   Reply With Quote
