Problem Child
![]() Join Date: Sep 2005
vapor canister
how can i get rid of the vapor canistor on my 72 c10 is their anything i have to do besides remove the hoses
1972 gmc sierra grande 350/350 a/c soon`to get a new 350 ![]() ![]() ![]() |
Re: vapor canister
If you plug the line you'll want to get a vented gas cap.
71 Blazer / GMPP ZZ383 / MPFI / 700R4 / 4-Wheel Disk / Ground-up frame off almost completed resto-mod |
its all about the +6 inches
Re: vapor canister
out of curiosity...why would you do this?
![]() ![]() Join Date: Jan 2005
Re: vapor canister
My old '67 made my garage stink with fuel vapors. My '72 does not. I'm assuming it's because it has a canister. Personally I prefer not having the cloud of fuel in my garage.
Problem Child
Re: vapor canister
i may keep it then i wasent really sure what it was for thanks
Re: vapor canister
The canister is a fuel recovery system designed to reclaim unburned fuel and send it back to the gas tank. One of the early smog/efficiancy systems.
1971 Chevy C10 Shortbed Stepside, 307v8 3-on-the-tree |
#7 | |
Re: vapor canister
Cory321, you should keep it hooked up if there is no good reason to remove it. What could possibly be wrong with recovering fumes from the gas tank that would otherwise be lost? Just make sure the vacuum hoses are in good shape and not causing a vacuum leak. It's one of the few emissions things that actually make sense. I went to great pains to hook mine back up.
What are you looking at?
Re: vapor canister
ok here is a dumb question...where the heck is the vapor caniter? I have looked everywhere for mine and can't find it...maybe the PO removed it.
1971 GMC LWB 2005 Honda Element 2007 Honda Fit ![]() |
#9 | |
Re: vapor canister
Re: vapor canister
I'm thinking it is 71 and 72 on the 49 state trucks....NFC on the Cali trucks.
