Old 10-27-2005, 08:09 PM   #1
Tx Firefighter
Watch out for your cornhole !
Tx Firefighter's Avatar
A Stupid SM465 Question
Say a fellow had a few SM465 transmissions in his private parts stash. Say this same fellow wanted to put one in a short bed truck with a 1 piece driveshaft....
Is there a slip yoke for these transmissions?
They all have bolt on yokes right now, for a multi piece driveshaft with slip coupling in the middle. I am wanting to use a slip yoke so I can retain a 1 piece shaft in this truck.
Can it be done?
Old 10-27-2005, 09:38 PM   #2
tnblazerk5
User #12137
tnblazerk5's Avatar
Re: A Stupid SM465 Question
i have no ideal about the slip yoke for tha trans but you could have a drive shaft made with the slip part in the drive shaft itself you know like the 4x4s use
tnblazerk5 is offline   Reply With Quote
Old 10-27-2005, 10:03 PM   #3
Russell
Professional Grade
Russell's Avatar
I've never heard of a slip yolk for an SM465. Not to say it doens't exist, but I doubt it
1995 Chevrolet 2 Door Tahoe (6.6L LBZ Duramax / ZF6 / NP241 with 1 ton solid axle swap)
Russell is offline   Reply With Quote
Old 10-28-2005, 04:05 AM   #4
4x4Poet
http://www.novak-adapt.com/catalog/sm465_parts.htm
#26 on the side index of parts lists the spline and shaft diameters or the three output shafts that SM465s came with. The 2wd version of SM465s came in GM trucks somewhere from ~'73 to ~87. Did 2wd GM trucks ever use splined driveshafts?
'71 GMC K20 Suburban, '71 GMC K10 Suburban, '72 Chevy C10 CST Suburban, '72 Chevy K20 clunker pickup.
4x4Poet is offline   Reply With Quote
Old 10-28-2005, 04:54 AM   #5
'68OrangeSunshine
'68OrangeSunshine's Avatar
Actually, 4x4POET, the SM465 came out in the 1968 model year in US Chevy truck production. Canada [and GMC] kept the SM420 until they ran out of them in about '69.
Old 10-28-2005, 05:51 AM   #6
4x4Poet
Smile
I know. My K10 burb and K20 pickup both have SM465s.
I just didn't word it that way because I was clumsily trying to say that since we know that 67-72 2wd GM trucks didn't come with slip yoke'd SM465s, maybe some of the 73up 2wd GM trucks had slip yokes. Especially the later '78up 2wd model SM465s that had 32 spline output shafts. I think the 32-spline output shafts stuck out further than the 10-spline & 35-spline output shafts. Of course, we know for sure that no slip yoke would ever have been made for the 10-spline units.
Novak mentions the 68-91 year run on the page before the parts page I linked:
http://www.novak-adapt.com/knowledge/sm465.htm
Good catch on my poor wording, though. *Knowledge* is good.
Old 10-28-2005, 06:24 AM   #7
Tell this fella not to feel stupid.He has asked an interesting question.I would go with a slip-yoke shaft.
Old 10-28-2005, 06:47 AM   #8
4x4Poet
TxFf, if you get stuck on this, knowledge wise, perhaps a driveshaft shop would have info on the dimensions and spline count of available slip yokes that you could match to the Novak #26 output shaft info. Slip yokes are common spicer parts, no doubt. Maybe they know or their books have the info.
Old 10-28-2005, 08:56 AM   #9
lilred67
lilred67's Avatar
tx ff.i installed a sm465 in my shortbed.i used the complete drive shaft from a '68 lwb,swing bearing and all.i had to have the front drive shaft cut to length,it worked out good. but to answer your question i've never seen a sm465 with a slip yoke.
lilred67 is offline   Reply With Quote
Old 10-28-2005, 11:02 PM   #10
wolfthing2000
Call your local driveline guys and let them set you up!! I have Jeeps and this is a no-brainer for a good driveline shop.
wolfthing2000 is offline   Reply With Quote
Old 10-29-2005, 12:55 AM   #11
kwmech
Never seen anything but a fixed yoke on the back of a 465, reason being, when you tighten the bolt/nut that holds the yoke on, it 'clamps' the rear output bearing tight thus locking the mainshaft in place. On the 4wd model there is a big nut with a lock/fold over washer that accomplishes the same thing.
Old 10-29-2005, 06:15 AM   #12
'68OrangeSunshine
Sorry Poet I didn't mean to come off like an <<E/Bully>>. I have a C/10 and a K/5 both with SM465s, too.
Tex, my DI used to say "the only dumb question is the one you're afraid to ask."
Anyway I'll just sit back and copy the mail here, since this discussion has gotten over my head.
Old 10-29-2005, 06:37 AM   #13
67-72williso
Junk/Daily Driver Club
67-72williso's Avatar
4x4 used 10 spline 68-79. 4x4 used 32 spline 80-up. 2WD used 35 spline 68-up solid yoke.
Later Willis
Daily Driver: 1970 C-20 400 sbc,sm-465,Dana 61 one ton SRW rear, 3.07 gears, locker.
There are three kinds of people: those who make things happen, those who watch things happen, and those who have no idea what happened!
67-72williso is offline   Reply With Quote
Old 10-30-2005, 10:42 AM   #14
Tx Firefighter
Thanks for everyone's input on this.
The reason I was asking is that I'm putting a beater short bed truck together and trying to get it completely done for under 1000 bucks cash outlay. I had 2 SM465's, so I figured to try and use one of them. But, in the meantime, I traded some welding work for a good Saginaw 3 speed. A 3 speed isn't sexy, but cash wise, it is free. So, the SM465's will be used on somethig else, later down the road.
Again, thanks for all the help here fellows.
Kevin
Old 09-06-2014, 07:28 PM   #15
RoughKuntry
RoughKuntry's Avatar
I have the Bulldog SM465 the problem being I own 2 of them. One is hooked up to a NP205 T-case in my 73 gm 1 ton and I need help on how to get it off the engine.
RoughKuntry
73 GMC 25 HUNDRED :Sold
79 GMC High Sierra 4x4 (Ma-Duece) :Sold
99 Chevrolet LS 4.8l/5 Speed Manual 4x4 :Selling
88 Chevrolet Burban 2500 4x4 :Buying
RoughKuntry is offline   Reply With Quote
