Old 10-27-2005, 09:52 PM   #1
red71cheyenne
Back in the sticks
red71cheyenne's Avatar
What I did today...pics
My favorite guy, the UPS man came today. Look what he dropped off:
red71cheyenne is offline   Reply With Quote
Old 10-27-2005, 09:55 PM   #2
red71cheyenne
Back in the sticks
Re: What I did today...pics
Of course I had to put them on
Old 10-27-2005, 09:57 PM   #3
67Fleet
Outlandish Trends - FL
67Fleet's Avatar
looks good. Are you going to shave down those upper tabs? I have clearance problems with those if I try to bolt up some chrome valve covers.
-Bret
67 short-fleet sold!
67Fleet is offline   Reply With Quote
Old 10-27-2005, 09:58 PM   #4
Tx Firefighter
Watch out for your cornhole !
Tx Firefighter's Avatar
Looks like your engine mount frame stands are installed wrong. They should set on top of the frame rail, not underneath it.
Old 10-27-2005, 10:11 PM   #5
red71cheyenne
Back in the sticks
Dude seriously? It came to me in pieces, so I'm not sure. HELP!!!!
1971 Cheyenne C-10 w/700R4 and Tuned Port Injection
1969 K5 Blazer w/Tuned Port
2010 2SS/RS Flaming Orange Camaro
2011 K1500 Suburban
2014 K1500 Pickup
2008 Nissan Altima? The wifes' hoopty
Old 10-27-2005, 10:36 PM   #6
Bowtiefreak
Bowtiefreak's Avatar
Yep,they are wrong. Unless these are something other than standard sm. block mounts. Shouldn't be hard to fix tho.
1968 Chevy C10 Short Fleetside/Wood floor
ECE 4-6 Drop / 406 Small Block
1971 Chevelle 427 Big Block
Bowtiefreak is offline   Reply With Quote
Old 10-27-2005, 10:37 PM   #7
red71cheyenne
Back in the sticks
67fleet, thanks, no I'm going with the stock looking valve covers, so hopefully it won't interfere.
Tx Firefighter, the factory assembly manual shows them like that. Are you sure mine are wrong? Thanks, Jeff.
2011 K1500 Suburban
2014 K1500 Pickup
Old 10-27-2005, 10:38 PM   #8
N2TRUX
Happy to be here
N2TRUX's Avatar
Those look good. Just curious why you went with 2" rather than 2.5"?
Articles-
"Jake" the 84 to 74 crewcab
"Elwood" the77_Remix
85 GMC Sierra "Scarlett"
"Refining Sierra"
Old 10-27-2005, 10:45 PM   #9
red71cheyenne
Back in the sticks
N2TRUX, I didn't know there were different sizes of factory manifolds. I just ordered the size that fit. Will it make a big difference? Thanks, Jeff.
2011 K1500 Suburban
2014 K1500 Pickup
Old 10-27-2005, 10:49 PM   #10
Green Machine
Green Machine's Avatar
Lookin good !! Yep, my frame monts are on top of the frame too.
1968 C10 307 3spd Long Fleet ------ http://67-72chevytrucks.com/vboard/s...d.php?t=201103
1970 C10 305 Super T10 Long Fleet --- http://67-72chevytrucks.com/vboard/s...d.php?t=202285
1971 C20 383 TH350 Dana Posi ----- http://67-72chevytrucks.com/vboard/s...d.php?t=206894
2001 GMC Sierra 1500 C3 6.0
Green Machine is offline   Reply With Quote
Old 10-27-2005, 10:53 PM   #11
Tx Firefighter
Yes, the mounts should set atop the framerails. That way ,the rails support the mount and engine weight. The way you have them, the two 3/8 bolts are in tension and carrying the whole weight of the engine by hanging under the framerail.
If your bolts failed, the mounts would fall and allow the engine to drop. If they were atop the rails like they should be, you could basically remove the bolts and the engine would still be supported ( though it would move around side to side without the bolts installed)
Old 10-27-2005, 10:59 PM   #12
red71cheyenne
Back in the sticks
Well, I'm glad you noticed them now, instead of me finding out down the road with broken bolts. Thanks, Jeff.
2011 K1500 Suburban
2014 K1500 Pickup
Old 10-28-2005, 10:39 AM   #13
Yukon Jack
Post Whore
Yukon Jack's Avatar
That is interesting as both my 69 K20 and my 70 K5 have the engine crossmember mounted like in the above picture.
1970 Blazer with a 400 sbc and 4" lift
1980 Pontiac Trans Am, 455 Oldsmobile
2012 Kawasaki Concours 14
Yukon Jack is offline   Reply With Quote
Old 10-28-2005, 12:15 PM   #14
Guardrail
And Don't Call Me Shirley
Guardrail's Avatar
Like this....
Rick Tucker
1969 C20/Custom Camper (the Green Machine)Sold
1970 GMC 4000 COE (future Ramp Truck)
1972 K10 Longbed (restoration begins June 2020)
Guardrail is offline   Reply With Quote
Old 10-28-2005, 12:21 PM   #15
Johns70
Johns70's Avatar
red71cheyenne those are right if thats in a four wheel drive and wrong if its a two wheel drive.
69 chevy short wide box project
70 GMC jimmy project
Johns70 is offline   Reply With Quote
Old 10-28-2005, 12:46 PM   #16
stllookn
Saving 1 truck at a time!
stllookn's Avatar
That has to be a different style of mount. The standard 2wd small block mounts are impossible to mount under the upper frame rail without some significant modification.
Beat me to it...LOL! It should not be a problem...unless there is an alignment issue.
'68 C20 Longhorn 50th Anniversary 400/TH400
'68 C20 Longhorn 50th Anniversary 468/TH400w/buckets
'72 C20 Halfhorn (Longhorn w/o cab and front clip)
'69 Flxible Cruiser (look up ugly in the dictionary)
stllookn is offline   Reply With Quote
Old 10-28-2005, 01:05 PM   #17
70rs/ss
70rs/ss's Avatar
I am guessing it is a 4X4 and yes it is correct. We should be careful about casting our opinion about without first getting the just of the situation. I just walked out and looked at my two 4X4's and the mounts are under the framerail. So if the truck if 4X4 then its correct if 2wd then it needs to be swapped
70rs/ss is offline   Reply With Quote
Old 10-28-2005, 01:45 PM   #18
red71cheyenne
Back in the sticks
Ya, this is on the Blazer. Sorry, should have specified that when I was posting pics I guess. Thanks to all that looked and replied. Jeff.
2011 K1500 Suburban
2014 K1500 Pickup
