R.I.P. E.S.L.L.
![]() ![]() Join Date: Aug 2005
3/5 springs ?? I dont want it lower in back
My truck has 7 inches of space between the body and the tire in front, and 7 inches between the body and the tire in the rear.
So if I lower it 3 in the front and 5 in the rear won't it be pointing up in front ? I don't want that. I'll be putting on lowered shocks with the springs. I have seen 3/5 pic's and they look great, I just am getting stuck on the math. ![]() Here is how it sits now. is it higher in front than usual??? ![]()
1971 Custom C/20 ![]() 1970 CST 20 1970 C/30 Flatbed 1983 C/30 Dually 2015 Corvette Z51 2021 Corvette Z51 1991 Cadillac Hearse 1982 Cadillac Eldorado Biarritz 2000 Porsche Boxster S 2020 Jeep Gladiator 1973 VW Thing 1973 Plymouth Satellite wagon 1963 Baja Bug 1959 Bug Dune Buggy 1970 Baja Bug 1987 Jaguar XJ 350. R.I.P. El Jay R.I.P Jessie. R.I.P Grumpy. Every day is a gift from God. |
Outlandish Trends - FL
Re: 3/5 springs ?? I dont want it lower in back
looks higher front & rear than usual. The top of the frame rail is higher than the top of your tire!
-Bret 67 short-fleet sold! |
Watch out for your cornhole !
![]() Join Date: Jun 2003
Do you have an engine and trans in that truck?
Smell that burnin' rubber
The reason for the difference between front and rear spring drop values is that these trucks originally had a rake (rear higher). So originally, the rear would be roughly 2" higher than the front. With age, the rear springs often settle out more than the front and the truck tends to level out. An ECE 4/6 drop for example will result in an almost level stance with only a slight rake.
R.I.P. E.S.L.L.
Yes it does have a 292 and a 3 speed in it. I think it looks higher too. It has some big old shocks on it look like from the 70's could that be the reason. maybe someone was worried about clearance when they put the mags on it.
67 is sold
That will be corrected when you use new rear shock brackets and shocks with the springs
![]() Do the drop ![]() |
May have been that the PO put some heavy duty springs in it at some point, or lift springs or something. It definitely doesn't look to have a stock stance. Either way, once you get your drop springs I think it will come down a little more than 3/5 from what it is now. I would also recommend the shock relocators for the rear. I couldn't believe the difference it made to my shock angles out back. They were at about a 45* angle before I put them in.
The front wheelwell openings are larger than the rear wheelwell openings. I made the same mistake when I was measuring my truck so I could decide how far to drop it. Measure from the ground (level) to the bottom of the body in front of the rear wheelwell and behind the front wheelwell. That should give you your stance. If it is sitting level and you want it lower in the front then you need to lower the front more than the rear.
Got bored, sold everthing. Got bored, looking for a 1960-66 C-10. Want to build my last truck. |
Early Classic's website has a stance page, which shows pictures of these trucks with varying drops.
Whatever the reason it sets so high now, once you swap all 4 springs out, your truck will set real close to everyone else's truck with the same drop as you did.
R.I.P. E.S.L.L.
I took Tomatocity's advice and measured it from the floor and sure enough it's 16" in the back and 14" in the front. THANKS TOMATO
Are you going to keep the slots? They look really good on there.
"You can take the man out of PA, but you can't take PA out of the man" |
#12 | |
R.I.P. E.S.L.L.
I really like Chrome Ralleys with the dog dish caps. $$$$$ will decide.
