Old 10-28-2005, 12:09 PM   #1
Davy
Davy's Avatar
Steering Knuckles questions.
Are the steering knuckles from a late 70's-early 80's D44 the same as the knuckles from a 1971 D44?
Is there a difference between 1/2 ton and 3/4 ton knuckles?
Thanks,
Dave
1970 Blazer CST
Looking for NOS items for my CST restoration.
Davy is offline   Reply With Quote
Old 10-28-2005, 12:16 PM   #2
toroflow
Re: Steering Knuckles questions.
nope, they are the same, 1/2 ton or 3/4 ton. and the knuckles are all the same whether its a dana 44 or a 10 bolt, from 1969-ish to 1991.
Ken
'60 GMC 3/4T 4x4
'60 GMC Suburban 4x4
'64 GMC Suburban 4x4
toroflow is offline   Reply With Quote
Old 10-28-2005, 01:08 PM   #3
Chris_T
The knuckles are not all the same from 69-91. They will interchange, but the early Dana 44 knuckles have a 'flat top' passenger side knuckle that is desirable if you're considering changing to crossover steering.
Chris_T is offline   Reply With Quote
Old 10-28-2005, 04:55 PM   #4
Beast388
Suburbans RULE!
Beast388's Avatar
You also have to consider the tie rod. The early knuckles had the TRE's that pointed down and the later knuckles pointed up.
As long as you swap them around in pairs you should be fine. I am using my stock 1/2 ton '71 knuckles and tie rod on my '77 3/4 ton Dana 44. I retained the '71 knuckles for if/when I go to crossover steering.
--Ben
71 GMC Suburban 4X4
The "Beast"
388 CID Stroker, TH350, NP205, 8-lug D44, 14BFF w/ Detroit, 4.10:1 gears, 4-Wheel Disks 4" Lift, 35" MT/R's.
Beast388 is offline   Reply With Quote
Old 10-28-2005, 11:15 PM   #5
Davy
Davy's Avatar
Thanks for the responses. As you may have guessed, I'm asking about knuckles because I am going to convert my 1970 D44 (drums) to disks. I've seen proof that the drum D44 knuckles are physically different than the disk D44 knuckles.....but I wasn't sure about the difference between years of the disk D44's (or 1/2ton vs. 3/4ton).
I know, I know.....get a complete disk axle and bolt it on, right...
Well, I have access to the individual parts pretty cheap and I am making sure all the associated pieces (ball joints, etc.) are new, so.......I will likely be building it (piece by piece) with my 1970 axle housing.
Any other suggestions?
Thanks again.
1970 Blazer CST
Old 10-29-2005, 02:33 AM   #6
Americanrider
Your going to have a hard time finding a straight axle in a 91. They went to IFS somewhere around 88 or 89.
Americanrider is offline   Reply With Quote
Old 10-29-2005, 12:54 PM   #7
JIMs70GMC
user # 2756
JIMs70GMC's Avatar
Boone, except for the K5s, burbs and 1 tons I believe went IFS in 92.
1970 K25, 8' stepside bed 350/465/205 44 up front, 60 in the rear 4.10s rolling on 33" Dunlop MTs
1986 K5, 350/465/208 Dana 60/14 bolt from a cucv 36" Super Swampers TSL/SX
1983 K20 w/ CUCV axles, 350/700R4/208 sitting on 37" Goodyears
1986 M1031 6.2 diesel, TH400/NP205 locker in the rear and a LS in the front, all stock for now.....
1986 K30, 350/400/205 dana 60 and 14 bolt. I kept the drivetrain. Body/bad and chassis are gone.
1981 K30, 350/465/205 dana 60 and dually 14 bolt. Has a G80, and a flat bed. Going to replace the flat bed.
1985 K20, 350/400/208 10 bolt and SF 14 bolt. I wonder where I can find some 1 tons. Hmmmmm
JIMs70GMC is offline   Reply With Quote
Old 10-29-2005, 02:28 PM   #8
Blazers,Suburbans,And Cewcabs(V/R series).StandardCab`n`chassis through`89.
Old 10-31-2005, 03:55 AM   #9
Americanrider
I was thinking just pickups.
