Old 10-28-2005, 12:34 PM   #1
Green Machine
Green Machine's Avatar
Can you set rolling frame on is side for cleaning/painting ???
Gonna take the cab off today and will just have a bare rolling frame with old tires on it. Can or should I even attempt to set this thing on its side, resting on the side of the tires for cleaning, will it even sit or fall over ???, will I bend or wreck any axles or suspension ? Should I leave the rear shocks on so springs won't extend to far ??? Thanks for any suggestions.
1968 C10 307 3spd Long Fleet ------ http://67-72chevytrucks.com/vboard/s...d.php?t=201103
1970 C10 305 Super T10 Long Fleet --- http://67-72chevytrucks.com/vboard/s...d.php?t=202285
1971 C20 383 TH350 Dana Posi ----- http://67-72chevytrucks.com/vboard/s...d.php?t=206894
2001 GMC Sierra 1500 C3 6.0
Green Machine is offline   Reply With Quote
Old 10-28-2005, 12:46 PM   #2
FormerMember
Re: Can you set rolling frame on is side for cleaning/painting ???
I don't see how it would cause an issue if you moved it slowly.
FormerMember is offline   Reply With Quote
Old 10-28-2005, 12:52 PM   #3
Joe67
67 is sold
I agree, should be fine if you can get it up somehow. Be sure it is SECURE before working on it
Joe - Formerly 67c10step
1967 Chevy Stepside - ECE 4/6, fuelcell, 5lug - SOLD
gr8lakes - My ebay auctions
Click here to order forum apparel :: Click here to become a subscribing member
Joe67 is offline   Reply With Quote
Old 10-28-2005, 01:00 PM   #4
sneakysnake
It's a catastrophic success.
sneakysnake's Avatar
The only real problem I see is the gear oil in the rear end, with it up on its side if the seal aint what it used to be it might leak out out onto your brakes.
sneakysnake is offline   Reply With Quote
Old 10-28-2005, 01:38 PM   #5
Green Machine
I did think aout the brake thing, and it needs new brake and axle seals anyway, maybe I should just pull the cover now and drain most of it ? Do you think 3 or 4 guys could lift it ? Thanks.
Old 10-28-2005, 01:45 PM   #6
Joe67
67 is sold
4 guys might be a stretch. Why not a cherry picker on one side and lift it up
Old 10-28-2005, 01:57 PM   #7
Green Machine
Sometimes I'm so dense - I have the cherry picker still here that I borrowed to pull the engine - duhh - work smarter not harder - LOL that would be safer too.
Old 10-28-2005, 01:58 PM   #8
Joe67
67 is sold
Old 10-28-2005, 07:07 PM   #9
Geezer
Geezer's Avatar
I didn't have any problems.
If you can't drive it park it! If you can't park it milk it!
Geezer is offline   Reply With Quote
Old 10-28-2005, 07:31 PM   #10
farside847
farside847's Avatar
hey, its a new kind of wheelie!!! (get it, two wheels off the ground, haha. Oh, nevermind.)
1971 Chevy C10 Shortbed Stepside, 307v8 3-on-the-tree
farside847 is offline   Reply With Quote
Old 10-28-2005, 10:43 PM   #11
Green Machine
oh my gawd, the neighbors and people driving by are breaking there necks looking the way it is, wait till we get that frame on its side, that'll give em something to talk about - Thanks
Old 10-28-2005, 11:28 PM   #12
CG
BlahBlahBlah
why didnt you just flip it upside down?
Old 10-29-2005, 02:14 AM   #13
Russell
Professional Grade
Russell's Avatar
Hmm, I wish I had thought of flipping it over before I put the body back on, lol
I guess, I'm pretty much done painting the bottom side anyways, I just do a small stretch every time I'm out in the shop.
1995 Chevrolet 2 Door Tahoe (6.6L LBZ Duramax / ZF6 / NP241 with 1 ton solid axle swap)
Russell is offline   Reply With Quote
Old 10-29-2005, 10:15 AM   #14
69 air cab
I actually did the same thing as geezer picture after draining the rearend. Note that geezer kept it hooked up to keep from falling on him.........at least I guess that is what he did. The sucker will fall on you once you put water pressure on it. Clamp a 2x4 to it if you have to so it is braced up.
69 air cab is offline   Reply With Quote
Old 10-29-2005, 12:22 PM   #15
Russell
Professional Grade
Russell's Avatar
Thats only a good idea if you can trust the hydraulics you are working with.
I've got a fullsize skidsteer that I use for that kind of stuff all the time, cept its big enough to lift the whole truck, not just the frame.
However, I absolutely NEVER stand under, or let anyone else stand under a load that I've lifted. Infact, I hate to crawl out of the front, and jump under the bucket to get out of the machine if the bucket is too high to climb onto to get out.
I was once lifting a junk cab (relatively light for that machine, it honestly doesn't even feel it) and as I was bouncing along, I lost my boom hydraulic seal, the cab fell down extremely quickly as a result. I had the forks through where the back window once was, and after the boom failed, the bucket crushed the back half of the cab close enough to the ground that I could nearly pound a regular sized nail through it. I can hardly imagine if someone was standing underneith that thing!
That, and if I had that thing holding my frame up, and it failed then, you can only imagine the frame damage that'd occur!
I guess, he is using a pretty small front loader, but still, the same basic concept should be applied.
Old 10-29-2005, 02:51 PM   #16
Skruffy
Skruffy's Avatar
I think this looks perfectly safe.
Skruffy is offline   Reply With Quote
Old 10-29-2005, 02:58 PM   #17
phantom dually
Project92 SWB stepside
phantom dually's Avatar
Gotta love that!!
92 C1500 stepside 496 Stroker Competiton Engineering Ladder bars/QA1 coilovers. Dana 60 rear with 4.10 gear and posi. Bonspeed Palisade 20x12 in rear w/335/30/20 and 20x8.5 front w/245/40/20. 5/8 drop with Belltech springs/DJM spindles/drop shocks. WWS Progress thread http://67-72chevytrucks.com/vboard/s...d.php?t=140448
phantom dually is offline   Reply With Quote
Old 10-29-2005, 03:00 PM   #18
phantom dually
Thats why I ordered this!! Early Christmas!!
Old 10-29-2005, 04:44 PM   #19
69 air cab
that guy under that truck is nuts...........
now I like th corvettes........
Old 10-29-2005, 05:20 PM   #20
tomatocity
tomatocity's Avatar
Did it come with the Corvettes
Got bored, sold everthing. Got bored, looking for a 1960-66 C-10. Want to build my last truck.
tomatocity is offline   Reply With Quote
Old 10-29-2005, 05:26 PM   #21
69 air cab
phantom Dulley.............I'll trade you a truck for a corvette..........better still I'll trad you two trucks for a corvette and you can keep the rack.
I always wondered if those racks would really work in a 8' ceiling shop. Nice incentive to buy to convertibles. Nice Christmas present!!!
Old 10-29-2005, 08:02 PM   #22
70 shorty
Where's my beer?
70 shorty's Avatar
My buddy has that exact setup as far as the cars are concerned, not the lift. He has a hot rodded but beautiful conditon 66 convertible and just last week he bought a 97 36000 mile C5. Must be nice is all I have to say. Now as far as the frame goes, I was going to say, well you've got the frame on it's side, the bed on end, so now you've got to put a cab on it's back an take a picture of all 3 peices.
70 C10, shortstep, .30 over 250,Hurst shifted 3 spd parts hauler. Holley 390, Clifford Intake, Header, ported cylinder head, unknown bigger cam.
79 Corvette L82, 4 spd, black, red interior, headers, flowmasters, and unkown bigger cam.
'03 Grand Cherokee Laredo, 4.0 4x4 daily driver. 165K miles, and runs great
'08 Tahoe LTZ 4x4 155K
70 shorty is offline   Reply With Quote
Old 10-29-2005, 10:21 PM   #23
Green Machine
Got er did, used engine hoist in the center to lift on side, cleaned that side the reversed and lifted the other side, we had the rear end out, so it was pretty light, heres one of my bad pics again....thats my oldest son ,on his knees, running the pressure washer, he's really good at this, he hates dirt and is on a mission to kill it all -lol.
Old 10-29-2005, 10:50 PM   #24
Tycoon4u
Tooloose
Tycoon4u's Avatar
Sure glad I read this tread this morning. Got mine done today too. thanks guys!!
A legend in my own mind!!!
website: http://www.persmedequip.com/
'68 c10 (current project)
http://67-72chevytrucks.com/vboard/s...ht=cherry+bomb
'04 silverado (better halfs)
'07 wildcat 27rlwb(for sale) http://67-72chevytrucks.com/vboard/c...llinois&cat=17
Tycoon4u is offline   Reply With Quote
Old 10-30-2005, 07:55 AM   #25
69 air cab
ain't it fun. these are great truck to enjoy.........glad to see the kids are involved too. I really like to see someone at a stage in a restoration that I have already completed...........it make me realize I enjoyed it more than I remembered.
