67 is sold
Installing pitman arm?
My new power steering gear and pitman arm are on the bench.
Do I install the pitman arm to the gear BEFORE attaching the gear to the frame rail? When installing the pitman arm, is it OK to use the nut/washer to crank it down onto the shaft or should I have it pressed in? Thanks ![]() |
67 is sold
Re: Installing pitman arm?
Problem solved. I just ran both pieces up to my gear shop.
It will be ready at 4PM ![]() |
