Assembly Manuals
I think its about time I buy some new reading material, I have seen these books on EBAY for $35 +8 =$43 at my door. IS this a good deal or can I get it somewhere else cheaper. Or should I just stick with something like the Haynes or Chiltons manual.
What do you think?
72 Chevy 4x4 350 55 Chevy Bel Air 350/350 53 Matchless G80s (motorcycle) 06 Trailblazer SS 400hp LS2 |
Re: Assembly Manuals
Ahh, green bible, available from most retailers for $30. I use it often.
1971 Chevy C10 Shortbed Stepside, 307v8 3-on-the-tree |
The assembly manual I bought from the old "Golden State Pickup Parts" reprint 6 yrs ago is so unorganized and incomplete. If you don't mind rifling through a lot of engineering drawings with very little narration, some of which you need an engineering degree to understand. It definitely contains plenty of useful data if you're doing a full frame off or just curious and have plenty of time to research.
'72 GMC SWB C1500 Custom, frame-off in progress. 383 SBC, 9:1CR, Comp Cams XE262H, Scat internal balanced crank, Eagle SIR 6" rods, Keith Black dish pistons, Dart Iron Eagle 72/180 heads, Weiand Stealth intake, Stewart stage I water pump, Holley 4bbl vac sec, TH350 with B&M Shift Improver Kit. 12 bolt positraction. ![]() ![]() ![]() |
![]() ![]() Join Date: Jan 2005
I agree with farside847.
The service manual has been way more valuable to me than the assembly manual. |
