For those that have burbs with the factory rear window deflector, does this really help keep the rear window and tailgate (for those of us without barn doors) any cleaner ?
Or does it really just help suck up more fuel and make not-so-nice "noizes" in the wind at higher speeds? Thanks! |
'87 V20 4x4
Re: Rear Window Air Deflector
Welcome to the board. I had one on my wifes old s10 blazer before we sold it this spring and it really helped alot thinking bout buying one for this one actually I recommend it myself just my .02 worth tho show us some pics of ur project when ya can
Doc
'86 K5 Blazer 4x4 FOR SALE '87 v20 4X4 '99 S10 Blazer 4X4 ![]() ![]() Last edited by a28doc; 10-29-2005 at 02:30 AM. |
user # 2756
![]() Join Date: Jun 2001
My 89 appears to have had one, but it is no longer there, I know they help and plan on getting one. It helps keep exhaust gases out of the vehicle when the rear window is down.
1970 K25, 8' stepside bed 350/465/205 44 up front, 60 in the rear 4.10s rolling on 33" Dunlop MTs 1986 K5, 350/465/208 Dana 60/14 bolt from a cucv 36" Super Swampers TSL/SX 1983 K20 w/ CUCV axles, 350/700R4/208 sitting on 37" Goodyears 1986 M1031 6.2 diesel, TH400/NP205 locker in the rear and a LS in the front, all stock for now..... 1986 K30, 350/400/205 dana 60 and 14 bolt. I kept the drivetrain. Body/bad and chassis are gone. 1981 K30, 350/465/205 dana 60 and dually 14 bolt. Has a G80, and a flat bed. Going to replace the flat bed. 1985 K20, 350/400/208 10 bolt and SF 14 bolt. I wonder where I can find some 1 tons. Hmmmmm ![]() |
Mine's always had the deflector and, yes, it does indeed keep the rear window clean. In fact, it eliminates the need for a rear windshield wiper. I can attest that it even works in a Michigan Upper Peninsula winter.
Semper Paratus |
![]() Thanks for the input everyone. I managed to find one off an 87 and should be getting it in 2 weeks or so. Also, should be getting my Elite Hedman headers in about 2 weeks. I'll post some pictures in 2 weeks when I get my camera back from my buddy. BTW, did I happen to mention that for some reason, everything is going to be happening in 2 weeks? ![]() |
Ok, received the deflector yesterday and I'm having a bit of a delema. I'm not sure if it's cuz of Veteran's day or what, but my brain just isn't working right today!
Could someone please post some pictures of their delfector from the rear of their burb and some up close pictures of the brackets? The deflector came with the original GM instructions and it says to mount all three rear bracket bolt holes 1.6 inches from the crown or crease of the back, where the rear of the burb begins. It seems like a rather large gap between the bottom of the visor and the top of the burb, but maybe I'm miss-reading the instructions. I'm temporarily holding it up with a gallon of antifreeze so I can move it around and I'm running a little less than 1 3/4" between the rain gutter and the visor. This gap seems a bit big. Most of the deflectors I've seen from other members pictures put the deflector almost right on top of the rain gutter. Unfortanetly, we have a lot of burbs and blazers in the area but almost none have a deflfector and the ones that do have the plastic modern deflector. I was just wonder if the above measurements sound about right? Or does it not really matter? Also, does the visor ends need to be pushed into position? The visor seems to have a bit of a bow to it. Sorry about the crappy pictures, the day was late and the burb isn't drivable at the moment. I can take some better ones in a day or so. The ends are drupping cuz of the bow in the visor, causes the ends to push forward about 1/2". ![]() ![]() ![]() ![]() ![]() Thanks. Last edited by stkcode; 11-14-2005 at 01:11 AM. |
I just went out and looked at mine. I looks like you've got it pushed a little too far back.
OK, bear with me a bit while I try to describe it in detail. There is a plastic spacer between the curved metal bracket and the roof. In your photos, it appears that this plastic spacer is "hanging out" in the rear. The proper front-to-back alignment is that the front edge of the spacer is lined up square and flush with the front of the curved bracket. The rear edge is about 1/8" forward of the rear roof bend above the rain gutter. In other words, the rear of the plastic spacer is located at the rearmost portion of the flat part of the roof. Of course, the left-right centering is self explanatory. I hope this helps. -Kevin '86 Suburban with factory air deflector
Semper Paratus |
Thanks! That did help.
70+ ( Old Skool Club )
![]() Join Date: Nov 2003
Hi Jon;
I bought this burb the other day and it I'm sure the spoiler on it is factory. Look at the pics and se if this helps you.
1972 C10 Custom/Deluxe 613 Highlander 406/700R4 1999 White Tahoe LS 4x2 with Z56 Police Package 1992 K1500 GMC Suburban Members I have personally met: MusicMan70 - HeavyD - ChewyChevy67 - StingRay -71SWB4x4 - 67 Burb - DeadheadNM - too much stuff - bc65 - das601 " Circumsatances Do Not Change Responsibility " " The Sky is not the Limit, Your Mind is." Marilyn Monroe .. RIP Charlie Watts 1941 - 2021 Last edited by Already Gone; 01-04-2006 at 02:44 PM. |
#10 | |
Tonawanda 454
91 Chevy Suburban Tonawanda 454 R2500 - SOLD!!! ![]() 04 Dodge Durango 5.7L Hemi 2WD, 24K miles (as of July 2011) In the past 30 years about 90% of Fords are still on the road, the other 10% made it home. ------------------- |
pretty funny to find this old thread about this rear deflector.
I am getting the feeling it has no use at all...We drive our burb about 100 km/h all the time (about allmost 60 mph) and it rains a lot here in the netherlands and even in heavy rain I dont see the water moving down the back window, it just seems to sit there. but then agai I have no reference, but would love to take it off...I think it looks strange on our Burb on the back
My dreamride / project:1977 GMC C15 Suburban In storage: Monster - 1974 GMC Suburban 25hundred Sold : Chevrolet Suburban K20 Silverado 1986 Guide: real HID projectors for 4x6 headlights link: DIY LED TAILLIGHTS |
#12 | |
78K & 79C Jimmys
sure seemed to help clear the back better then the 87 without i took it off now, for the Jimmy,it helps keep the exhaust out too you could remove the top half see if it helps/works even less but may need to angle it more .... don't have many pics of it
John 1978 GMCJimmy4X4-350/203 1979 GMCJimmy4X2-305/350 |
#13 |
78K & 79C Jimmys
and just thinking too the rain gutter will keep the rain going to the sides
lol the 78 burb sprayed water in threw that gap lol
#14 |
Resident of Here
I just took mine off. No difference in dirt. And my truck is white so it's easy to see up close. It's just as filthy as before.
~Bradley~ 2004 Black GTO LS2/T56 too much to list ![]() Miss having a truck ![]() |
#15 |
I've had a kid I used to work with try and tell me I ought to get one for my Burb, but myself, I'm just not a fan of it. That and where I live using one of those to keep dirt off the back would be like Daffy Duck using a pail to save his sinking boat. lol.Yeah he always got a lot of water out of the boat, but in the end he was always sunk.
"I just don't think my Suburban Has much to do with climate change, oh woah, Has much to do with climate change and my mind you cannot change..." Tim Hawkins - Free Bird Parody ![]() |
#16 | |
