headlight problem
I got my relays mounted and ready to hook to the headlights BUT I got a slight problem first. I got a 69 GMC with four headlights, halogens to be specific, when I have them on bright all is just fine. When I put them on dim the two outer light are on like they are supposed to be but not as bright as they should be and the two inner lights can be seen barely glowing when they shouldn't be. I thought bad grounds , so I took the grounds loose and cleaned them to the bare metal... Didn't help. so I tried cleaning the terminals on the sockets and bulbs... didn't help. BUT while I had one of the inner bulbs out I took a piece of wire and stuck it down in the socket on the ground side then touched it to ground with the dim lights on .... no help. Then I took that same piece of wire and touched it from the ground side of the socket over to the other side of the socket and the two dim lights got brighter like they should be and the other dim light wasn't glowing. Does any body have an idea what could cause this? should I go ahead and wire up the relays and take a 50/50 chance that it could solve the problem?
If it don't fit, force it,...If it still don't fit , modify it 'till it does fit !!! ![]() ![]() |
20' Daredevil (Ret)
![]() Join Date: May 2003
Re: headlight problem
Strictly a guess.... bad dimmer switch?
![]() Join Date: Aug 2004
It seems like you may have righ resistance somewhere, causing the current to bleed back thru where you don't want it. How are all the connections, terminals, and such? Are they all soldered? I would say one of your connections or switches is funky.
ClusterTruck: 68 C10 Bought in 89, wrecked in 03. Slow low $ rebuild started '17. 6.0 & TKO http://67-72chevytrucks.com/vboard/s...d.php?t=788602 93 K1500 Short Step, 350, NV4500, EBL flash ECU. Vortec heads & roller cam someday... 05 Jeep Wrangler Unlimited. 3” lift & 6-speed 02 E320 the insurance total “free car” 13 Tahoe LTZ |
#4 | |
![]() Join Date: Dec 2002
when the relays are wired in.... the dimmer switch controls the relays for the required hi/low beam switching. If the dimmer switch selects the hi/low function; then the deiimer switch would be Ok.
'71 GMC;fleetside;PB/PS/AC/CC/402 Eng./Custom Paint/110,000act miles/3 fuel tanks(52gal). |
20' Daredevil (Ret)
Well - personally, I'd prefer to find & fix the problem before adding to/changing the wiring (relays). However, if it gets too frustrating, I would probably hook up the new stuff just in case that does fix - er, I meant bypass - the problem!
The dimmer switch does change them from bright to dim, it's just they have the problem mentioned above. Like I said, I've cleaned the bulb terminals, the plug terminals, both ground connections so it has to be some where in the wiring or the switch or the dimmer. I guess I could just go ahead and wire the relays in, If it still does it then I'll have to go from there. If it doesn't do it then I can say "what problem?"
its all about the +6 inches
Have you tried running a ground from the battery to the rad core support?
The back feeding is a classic bad ground indicator, and there is a chance that your ground strap has been torn or is missing all together. |
