Old 07-08-2002, 03:30 PM   #1
dion
72 Cheyenne
dion's Avatar
What kind of paint should I use on my inner fenders?
I've seen new ones painted and still rusted after a year, whats the best?
Burnout
Idle
1972Cheyenne
1966/67Stouts
dion is offline   Reply With Quote
Old 07-08-2002, 04:19 PM   #2
johnnyp
Keepin' It Stock
johnnyp's Avatar
Insides can be painted with any good paint - normally black, but have seen several painted same color as truck. Outsides (wheel wells) should porbably be protected with some kind of undercoating or tough paint such as POR-15. I perfer the POR-15 route because it's easy to touch up when (not if) it gets chiped from flying debri, but undercoating does help with noise.
72 Sierra Grande - Maych
Forget about "do it right the first time". Do it wrong the first time to learn how, then do it right the second time.
johnnyp is offline   Reply With Quote
Old 07-08-2002, 04:19 PM   #3
WHYBYNU
WHYBYNU when old will do
WHYBYNU's Avatar
I had a friend at body shop do mine not sure of the paint he used probably was Dupont base/clear came out great. Be careful putting them back in you don't want any scratchs. I was lucky I used plenty of masking tape around the corners and edges. I have had very good luck with rattle can paint jobs as well it's all in the PREP WORK and is to touch up as needed.
WHYBYNU is offline   Reply With Quote
Old 07-08-2002, 04:24 PM   #4
Alexis
Member since 2000
Alexis's Avatar
you could put some of that napa x-liner wanna-be stuff under the fender and . put a layer of POR-15 first......just an idea
Alexis is offline   Reply With Quote
Old 07-08-2002, 04:33 PM   #5
Longhorn Man
its all about the +6 inches
Longhorn Man's Avatar
i just did mine with Testors spray paint. They come out looking awsome, and this is the best rattle paint I have ever seen. I tis kinda expensive for spray paint, but you can find it by the models in wall mart or where-ever.
This stuff spray easy, high gloss, and very durable. The rust pprevention is pretty good too. Just use a good primer.
Old 07-08-2002, 06:19 PM   #6
Low69CST
I'm going to use an eastwood under engine paint. Its got a flat dark, but not quite black look to it. I want a flat paint so it doesn't show my poorly stamped Tiwan inner fenders.
'69 CST Short fleetside
Lowered, 400 small block, 700R4, 4 wheel disc brakes, front sway bar & rear camaro sway bar (in progress)
'87 V10 4x4 Short Fleetside
Quad Suspension and Dual Tanks
Low69CST is offline   Reply With Quote
Old 07-08-2002, 09:08 PM   #7
dion
72 Cheyenne
dion's Avatar
I have a gun, I'm going to spray them. I'll try Dupont. Thanks guys.
Burnout
Idle
1972Cheyenne
1966/67Stouts
Old 07-09-2002, 12:01 AM   #8
EighthD
EighthD's Avatar
I used single stage paint on my inner fender wells. Dupont or Ditzler paint will work. It just depends on what paint you used before. I have used both. If you need any help let me know. I live in santee.
EighthD is offline   Reply With Quote
Old 07-09-2002, 09:25 AM   #9
Yellow Cheyenne
I hope to powder coat my new ones before installing. We'll see if it happens.
'72 Cheyenne. AC, PS, PB, Rear slider window, tilt. Light yellow (grapefruit yellow according to new sales literature from '72)
'56 Chevy short step V-8 (My dad bought it new!!)
'70 Olds 442 convertible
'70 Olds Rallye 350
Yellow Cheyenne is offline   Reply With Quote
Old 07-09-2002, 07:27 PM   #10
72'BBGMCSGCC
I'll have mine painted gloss black and I'm going to have them Rhinolined on the inside to protect against rock chips . I've seen it done and it looks great.
72'BBGMCSGCC is offline   Reply With Quote
Old 07-09-2002, 09:46 PM   #11
O'skool 72GMC
O'skool 72GMC's Avatar
inner fender wells
i was going to powdercoat then at El Dorado's on commercial. right down the street from you!!! Real Durable and will last a long time.
O'skool 72GMC is offline   Reply With Quote
Old 07-09-2002, 11:38 PM   #12
busterwivell
I'm real happy with powdercoating the stuff I've done at home so far, but the oven won't hold 'em. I'm going to blast mine and have them powdercoated locally in gloss black. Hadn't thought about the tire side chipping, though.........I'll give that one some thought.
Bill - Tucson, AZ
47 Chevrolet 2 dr sedan
56 Chevrolet 210 2 dr sedan
66 Chevrolet Malibu 2 dr 4 speed
71 Chevrolet C30 Longhorn
86 Chevrolet Monte Carlo SS (Sold)
01 Chevrolet Tahoe
IM - BUSTERWIVE@aol.com
busterwivell is offline   Reply With Quote
Old 07-10-2002, 12:41 AM   #13
dion
72 Cheyenne
dion's Avatar
I'll find out in a few days or so but what would powder coating these things cost?
Burnout
Idle
1972Cheyenne
1966/67Stouts
Old 07-11-2002, 10:02 PM   #14
O'skool 72GMC
Powdr Coating
I'm thinking around 100
but u wont know until u call.
a guy at work got his mountain bike frame done for 50 bucks and it looks bad ass. El's is the best for the money.
