replacement p.s. reservoir hose
Hey there,
Stil putting finishing touches on my rig. Right now, I need to find the replacement hose from the power steering reservoir to the p.s. pump. My biggest concern is that the material of the hose. It is 1" i.d. hose and I do not want to use something that p.s. fluid will just erode. Has anyone got an idea of where to find this hose? I have not seen p.s. hose this big in the local stores. Thanks in advance for your help. -Chuck
Chuck 1972 C-20 Longhorn 402 BB .030" over (409?), curved HEI, RV cam, quadrajet, dual 3" exhaust, TH 400 ported w/shift kit 1999 K1500 Suburban (old style) 5.7L Vortec 4L60E "No matter where you go, ........ there you are" |
its all about the +6 inches
Re: replacement p.s. reservoir hose
NAPA should be able to... if they can't, then I'll see if I have some extra laying around at work.
#3 | |
I tried every parts place that I could think of and finally found one from Original Parts Group. Website: https://www.opgi.com/GateChev4.asp Part number is CH20278. $29.95....pricey but it fits properly and is the correct hose. It's listed as a big block Chevelle hose. Regards, Larry
Larry 1949 Willys CJ2A, Kubota Turbo Diesel engine, Warn Overdrive, 11 inch brakes, 12volt, Warn M8000 Winch "Little Green" 1970 Rustoleum Roller Red C20 Custom Camper 454 TH400 "Big Red" 1971 K20 6.2 Turbo Diesel 4x4 4spd Ranger Overdrive "Pumpkin Wagon" 2005 VW Beetle Diesel 44+ MPG "Silver Bullet" |
wwe ran out at work. we use it on the P/30 step vans ...they have remote power steering reivours too.
Thanks All for the help and the pm's.
Is it the teflon coating on the inside that distinguishes them fro other rubber hoses?
