5/7 drop
Ok I lowered my truck 4/6 and its still a little to high. I bought my spindles and drop springs from early classic, my question is where do you buy 5/7 drop kits at?
thnaks |
Watch out for your cornhole !
![]() Join Date: Jun 2003
Re: 5/7 drop
In the front, get either a 2 or a 3 inch drop spring. That will give you 4.5 or 5.5 inches of drop depending on which you choose. I've never seen a 2.5 inch drop front coil anywhere. I like to use Summit racing springs myself. They are cataloged for 73-87, but interchange all the way back to 63. Plus, when you unbox them, they are actually Ground Force brand springs in a Summit box and no one beats the price.
In the rear, I have never seen a spring that drops lower than 6 inches. You'll need to run a 1 inch lowering block for that last inch.
www.73-87chevytrucks.com
![]() Join Date: Dec 1999
Re: 5/7 drop
You either need to cut the front springs, or buy a 1-1.5" dropped spring, for the rear you can get a longer rear shackle or a 1" block.
If you want a drop spring for the rear you will have to get them made. I had Steve's Suspension build me a set that are 6" drop, but they won't hold over 600lbs of load.
Chris Lucas 1973 Chevy C-10 1978 GMC Jimmy (2WD) - SOLD 1987 R10 twin turbo LS 1991 R3500 SRW CrewCab 1985 K5 diesel swapped project 1989 K5 2WD conversion w/ Vette susp Project Captkaos Customs 73-87chevytrucks.com |
Re: 5/7 drop
I'm assuming, going by his name, that he has a 72. Unless it's a 72 with rear leafs, he won't have a shackle option. Assuming it's coil spring, 6 inch drop coil is as low as anyone sells, so he has to use the lowering block.
Outlandish Trends - FL
Re: 5/7 drop
correct, and if you go to 7", you're gonna have to c-notch the frame as well. Be prepared to cut.
-Bret 67 short-fleet sold! |
![]() Join Date: Mar 2004
Re: 5/7 drop
here's a link to drop blocks and pinion angle shims. everone on the board i've talked to seems to like there product.
http://www.stockcarproducts.com/trkarm1.htm |
Re: 5/7 drop
I own a 69 Suburban 2wd, Does anyone have the part numbers for these drop springs and spindles from Summit racing
