Old 10-30-2005, 08:16 PM   #1
Green Machine
Green Machine's Avatar
Might these wheels/tires fit ?
Fit a 1970 6 lug stock height truck that is ?? Found these, they are off of a 2005 1500 - 17 inch 6 lug with 265/70 tires. I think the center hub size may be to small, I can't tell if they are aluminum or not, if aluminum I could have the center bored to fit I think, but mainly wondering what the back space and rim width might be, I know many have to much backspace for our trucks, and would that tall of tire clear especially on front ? I was thinking a 265/65 might be better, Any thoughts ? I really like the looks of those, Thanks
1968 C10 307 3spd Long Fleet ------ http://67-72chevytrucks.com/vboard/s...d.php?t=201103
1970 C10 305 Super T10 Long Fleet --- http://67-72chevytrucks.com/vboard/s...d.php?t=202285
1971 C20 383 TH350 Dana Posi ----- http://67-72chevytrucks.com/vboard/s...d.php?t=206894
2001 GMC Sierra 1500 C3 6.0
Green Machine is offline   Reply With Quote
Old 10-30-2005, 08:42 PM   #2
krue
Designated A-hole!
krue's Avatar
Re: Might these wheels/tires fit ?
I know the hub hole will be too small, I'm pretty sure the backspacing will be off, and I ran 33's (with about 50 percent tread) on my half ton with no issues, but I
don't know if that helps or not.
Being stupid ain't illegal.
www.daveramsey.com
93 S-10 "Poppaw's Truck"
Old 10-30-2005, 09:42 PM   #3
67Fleet
Outlandish Trends - FL
67Fleet's Avatar
hub bore will be too small for sure. You'll have to take your axles out and have the hub flanges machined down to 3" to accept those wheels. Your stock hub bore is approx. 3-1/2". BTW, those wheels are steel, and machining the wheels is the wrong way to do it. Machine the axles and you'll never have to worry about what wheels you want to run again. Also, krue is right about the backspacing. Especially out back as the tires will rub your inner fenderwells. Backspacing is too much.
-Bret
67 short-fleet sold!
67Fleet is offline   Reply With Quote
Old 10-31-2005, 03:54 PM   #4
70rs/ss
70rs/ss's Avatar
Back space for our trucks should be around 3" and the new trucks are about 5". the rears will rub and you might have interferance with you front suspension and steering componenets as well. You could try whell spacers...On second thought 2" is too much for a spacer, just pass on them.
70rs/ss is offline   Reply With Quote
