![]() Join Date: Sep 2005
283 building questions
How much power can you get out of a 283? What type of carb setup?A 2bbl, 4bbl,3 2bbls
01 2500 Duramax,6spd,4x4,Not stock. Estimated 550rwhp/1100rwfp on fuel only. 03 3500 Duramax,6spd,4x4,Pac-Brake,not stock Estimated 500rwhp/1000rwfp fuel only 67 K10 in many pieces Little Brothers truck 67 K20 Cummins 12V/NV4500/205, D60/Eaton w/ Detroit,37" Xterrains,crossover steering, Future plans,Twins and lots of fuel. |
Re: 283 building questions
I was thinking of building mine with a 305 TPI setup and Vortec heads. I'm not sure about power numbers. Sounds like you'll have a decent running truck there. Do you plan to run a low gear like a 4.11 or 4.56? I know smaller engines like lower gears. Good Luck and keep us updated.
It's going to be for my little brothers truck. It's going to have 5.14's unless we decide they are too low then we will run 4.56's.We have both sets of gears so it's no big deal.I was hoping to get him some good power an well as be efficient.Plus not very many people have 283's.
I`d go with an RV cam,low-end torque/economical cruising,hei,1.94"heads,4bbl(no more than 600cfm),headers,and flex-fan.If you`re doing a rebuild,you could go to about 9.5:1-10:1,an over-bore(to a 301),balancing,and porting(along with port-matching heads/manifold).
Any idea how much HP?? Could it make 300hp and still be efficient.
#6 | |
It's called "drag racing" if they called it "tic..tic..WHAM!..BANG! F*&K!!!", they'd have to keep the magazines under the counter with the other men's publications click the clicky to join the site.... http://67-72chevytrucks.com/vboard/payments.php 67 lwb..first hotrod in 25 years..540 best ET is 9.45 @ 141.44 Anderson,CA |
