Old 11-01-2005, 12:58 AM   #1
modifiedGMC
Headlight Problem Solved !!!
I found the problem with my light, what I thought was a bad ground turned out to be a bad plug on the driverside dim (outer) headlight. I decided to go ahead and wire the relays up to my headlights to see if it fixed it but it didn't. Then checked dimmer and found burnt plug, replaced that still didn't fix it. then ran new wires and plugs from passenger side and had driver side disconnected passenger side iner bulb didn't glow so I reconnected the old plug and wires and still no glow! so then I hooked the driver side up and they glowed. replaced the plug on driver side and problem solved!! After driving tonight with the relays hooked up I was amazed how much BETTER I could see the road! I done some volt checks before and after and this is what I found: 13 volts at battery, 11.5 volts at the dim bulb (before), 10.10 volts at the bright bult bulb (before), I was also getting 1.8 volts on the bright bulbs when the lights were on dim, this is why iwas getting a slight "glow" from the dim bulbs. after I wired the relays I got 12.16 volts at dim bulb, 11.79 on bright bulb and after replacing driver side dim plug no glow from bright lights. It was well worth the effort. Total cost of job... less than $5 by using two relays and plugs from salvage yard!
If it don't fit, force it,...If it still don't fit , modify it 'till it does fit !!!
modifiedGMC is offline   Reply With Quote
Old 11-01-2005, 03:21 AM   #2
stllookn
Saving 1 truck at a time!
stllookn's Avatar
Re: Headlight Problem Solved !!!
Cool conversion. What vehicles did you find the relays in at the JY?
'68 C20 Longhorn 50th Anniversary 400/TH400
'68 C20 Longhorn 50th Anniversary 468/TH400w/buckets
'72 C20 Halfhorn (Longhorn w/o cab and front clip)
'69 Flxible Cruiser (look up ugly in the dictionary)
stllookn is offline   Reply With Quote
Old 11-01-2005, 09:51 AM   #3
Stocker
20' Daredevil (Ret)
Stocker's Avatar
Glad to hear you found & fixed it! Electrical gremlins can be a real PITA....
- Mike -
1972 K20 LWB 350/350/205
RIP El Jay
Stocker is offline   Reply With Quote
Old 11-01-2005, 08:59 PM   #4
modifiedGMC
I found these two both on an older pontiac grand am. They were mounted on the firewall side by side. 12 volt 30 amp. All I done was put bigger wire and made them the correct color to hook to my GMC so it would easier to trouble shoot if the need ever comes up. I've also got an 86 IROC that has the same relay mounted on the driver side fender by the horn but only one.
