Old 11-01-2005, 01:08 PM   #1
70short
Rear Gears
I have A "70 SWB" custom. The truck came with the original 4-speed transmission and 350 eng. I recently swapped it out with A TH400. Does anybody know what the original rear end gear ratio is. THANK YOU
Gary
"72" Red CORVETTE 4-speed 350
"70" Chevy Short Bed early stages of resto.
Edel 600 cfm carb
Weiand Stealth Intake
HEI
shorty Headers
4/2 Drop
295 50R 15 TOYO on 10 inch wide corvette rally rims at all 4 corners.
"CHEVY RULES"
70short is offline   Reply With Quote
Old 11-01-2005, 05:52 PM   #2
Longhorn Man
its all about the +6 inches
Longhorn Man's Avatar
Re: Rear Gears
Assuming no modifications...and no options listed on thew SPID label... you should have a 3.73.
I AM assuming you are talking 1/2 ton.... if not....
Assuming no modifications... and no options listed on thew SPID label... you should have a 4.56.
Old 11-02-2005, 03:17 AM   #3
70short
Re: Rear Gears
Thanks Longhorn Man!!!!!!! No modifications 1/2 ton.
Gary
Edel 600 cfm carb
HEI
shorty Headers
4/2 Drop
"CHEVY RULES"
Old 11-02-2005, 10:04 AM   #4
Rod
Re: Rear Gears
I'd say original equip in that v8 4 spd config is 3.07 gears.
Senior active founding member.
70 3/4 ton GMC Suburban 4x4 250/4 spd.
71 1/2 ton Suburban Chevy 4x4, 350/350
72 Chev 1 ton tow truck 402BB w/Holmes 440 wrecker on propane
2005 FLSTSCI Harley Springer
85 FXSB Harley Lowrider
72 Triumph 650 Bonneville 5spd
"Poor people don't have hobbies" Quote from wife.
Rod is offline   Reply With Quote
Old 11-02-2005, 04:19 PM   #5
Longhorn Man
Re: Rear Gears
mannn, I just looked it up, you ar eright Rod, I had thought that was standard with an automatic and small block...not simply standard with a small block.
Old 11-02-2005, 05:00 PM   #6
70short
Re: Rear Gears
OK so my gears are 3.07's is that correct? No modifications just went from original 4-speed to An auto TH400. THANK YOU
Gary
Edel 600 cfm carb
HEI
shorty Headers
4/2 Drop
"CHEVY RULES"
