Old 11-02-2005, 11:04 AM   #1
soundspecilist
Pertronix Ignitor Problems...
Hey Everybody! First time on the site and I'm loving it! I have a '69 GMC 1-Ton Longhorn, SM465, 104,000 original miles. I just dropped in a new 350 w/ZZ4 lo-compression heads, big lopey cam, holly carb, and the latest upgrade was the swap from good ole points to the Pertronix Ignitor II and a new Flamethrower II coil. I am apparently the only person on the face of the earth whose performance has gone DOWN (the truck's performance, not mine!) by swapping out the points! Pertronix has no ideas, nor has anybody else I've asked. The cold starts are worse, it hesitates in the lower RPM's, and the mileage is worse than it already was. The plugs, wires, cap and rotor are fairly new, all the clearances for the Ignitor module meet their spec's... I'm lost. Can anybody help?
soundspecilist is offline   Reply With Quote
Old 11-02-2005, 11:13 AM   #2
jhow66
jhow66's Avatar
Re: Pertronix Ignitor Problems...
Did you have the Dist. out? Is the clearence the same all the way around? Is the dist. out a notch and made up by moving the dist. back or forward? Have you got # 5 & 7 plug wires crossed?
56 Chevy Bel-Air 2dr. HT (purchased new)
71 Chevy Cheyenne SWB PU (502HO)
65 GMC short bed step--work in progress and my gofer
jhow66 is offline   Reply With Quote
Old 11-02-2005, 11:41 AM   #3
soundspecilist
1) Yes.
2) Not Sure, but I'll check this weekend when I pull it again.
3) Distributor is in the correct position. I've learned from my mistakes on that one! (blown muffler from backfire, carb fire, fun stuff!)
4) 5 & 7 are correct.
A new stock distributor doesn't cost that much and the one in there is probably original. I'm thinking of buying a new one and seeing if that helps the issue. Thanks for the reply. I'll let you know what happens.
Old 11-02-2005, 11:53 AM   #4
cdowns
cdowns's Avatar
origal wiring in these trucks includes a resistor circuit//most changes require running a new wire to the dizzy for a full 12V supply
Old 11-02-2005, 12:06 PM   #5
soundspecilist
I did confirm that there was 12 volts being delivered to the coil. I haven't found a resistor circuit yet (nothing on the firewall or obviously displayed), but it could be hidden. I'll check it out.
Old 11-02-2005, 01:17 PM   #6
72 longhorn BB
72 longhorn BB's Avatar
I put a used GM HEI in my rig and when I did, It was recommended that I get the thing curved for my engine.
Never had a problem with it, but was told I could expect those kinds of problems if it wasn't checked out and matched to the setup I had.
Chuck
1972 C-20 Longhorn
402 BB .030" over (409?), curved HEI,
RV cam, quadrajet, dual 3" exhaust, TH 400 ported w/shift kit
1999 K1500 Suburban (old style)
5.7L Vortec
4L60E
"No matter where you go, ........ there you are"
72 longhorn BB is offline   Reply With Quote
Old 11-02-2005, 01:34 PM   #7
soundspecilist
I hadn't thought about recurving it. That's a good idea. Thanks!
Since you're a fellow Longhorn owner, any idea where I can buy a pre-fab bedwood kit? All I can find are either short or long bed, but no Longhorn. Can you help?
Old 11-02-2005, 01:39 PM   #8
cdowns
cdowns's Avatar
the resistor is the original wiring in the truck//not a seperate resistor//if you peel the wiring harness that goes accross the firewall the dizzy wire will go into a thicker wire thats lookin like it's wrappedv in old electricaltape that's the resistor circuit
Old 11-03-2005, 02:45 AM   #9
tomatocity
tomatocity's Avatar
I agree. Should be easy to test using a a new wire.
Got bored, sold everthing. Got bored, looking for a 1960-66 C-10. Want to build my last truck.
tomatocity is offline   Reply With Quote
Old 11-03-2005, 08:35 AM   #10
72 longhorn BB
I guess I'm a little confused - did you hook you HEI up to the existing wire that went to the old distributer?
If you did, thats' wrong. You need to go to the fire wall connector and remove the pin from the connector and replace the whole wire and terminal (buy them at Pep Boys) to the dizzy, regardless of what you measured at the wire. That wire IS the resistor and will never supply enough voltage to make your HEI work right.
After that, try recurving it if you still have problems
Chuck
1972 C-20 Longhorn
5.7L Vortec
4L60E
Old 11-03-2005, 10:25 AM   #11
soundspecilist
I didn't hook up to the original wire that went to the DISTRIBUTOR. The Ignitor came with its own lead for that. The only original wire is the one going to the positive side of the coil (which is a new Flamethrower). So are you saying that the Pos wire going to the COIL is the resistor lead? Sorry if I'm a little dense, but I want to make sure this is clear as mud before I get in there and start replacing wires.
'69 GMC C3500 1-Ton, Longhorn, SM465, built 350,
Old 11-03-2005, 10:32 AM   #12
Scrubby
Check out GMTrucks.org
He shouldn't need to recurve it. He only went from points to a pertronix. I'm guessing that he didn't touch the weights or springs, so no need for a recurve.
I would run a new wire from a 12 volt source and see what that does.
Scrubby is offline   Reply With Quote
Old 11-03-2005, 10:40 AM   #13
soundspecilist
I just filled up and got 10 MPG, mostly highway miles! I was getting 11 - 12 before the Pertronix. This weekend I'm going to tackle it and see what I can do. I'll update y'all after that. Thanks to everybody for the advise. Hopefully it will pay off!
Old 11-03-2005, 10:52 AM   #14
jhow66
jhow66's Avatar
Here is the way it should hook up:
Old 11-03-2005, 10:59 AM   #15
soundspecilist
That is awesome! Thanks for doing that! I just printed it. I may tackle this tonight!
