11-02-2005, 03:05 PM | #1 |
4x4 Front leaf springs
Can I use a set of 73-88 chevy front leaf springs on my 72 project. They are 8'' front springs but it pushes the shackle way back and I am wondering if it will off center my axle in the fender well?? dont really want to buy new ones since these are almost brand new??
Any help guys? thanks
1972 K5 - LS3/408 (595Hp) -6L80e-One Tons with 4.56, 20'' Beadlocks with 37'' rubber, full TMI interior, JL Audio ..... 1971 CREWMAX Build.....at body shop for couple more years |
11-02-2005, 03:09 PM | #2 | |
Re: 4x4 Front leaf springs
Measure from eye to eye on both springs and see if they are the same. If it appears to push the shackle back, then it is probably too long. |
11-02-2005, 03:20 PM | #3 |
Post Whore
The are too long unless you move your front hanger or relocate your rear shackles. A pair were on my 70 K5 when I bought it and the rear of the spring almost touched the frame.
1970 Blazer with a 400 sbc and 4" lift 1980 Pontiac Trans Am, 455 Oldsmobile 2012 Kawasaki Concours 14 Last edited by Yukon Jack; 11-02-2005 at 03:20 PM. |
11-02-2005, 06:45 PM | #4 |
user # 2756
73 and newer springs are 3" longer than the 72 and earlier, irregardless of the lift, they are still made to span and hold a certain length.
1970 K25, 8' stepside bed 350/465/205 44 up front, 60 in the rear 4.10s rolling on 33" Dunlop MTs 1986 K5, 350/465/208 Dana 60/14 bolt from a cucv 36" Super Swampers TSL/SX 1983 K20 w/ CUCV axles, 350/700R4/208 sitting on 37" Goodyears 1986 M1031 6.2 diesel, TH400/NP205 locker in the rear and a LS in the front, all stock for now..... 1986 K30, 350/400/205 dana 60 and 14 bolt. I kept the drivetrain. Body/bad and chassis are gone. 1981 K30, 350/465/205 dana 60 and dually 14 bolt. Has a G80, and a flat bed. Going to replace the flat bed. 1985 K20, 350/400/208 10 bolt and SF 14 bolt. I wonder where I can find some 1 tons. Hmmmmm |
11-02-2005, 10:47 PM | #5 |
What we are saying is,yes they`ll work.But,not a bolt-in.You need to relocate the mounts.Three choices:move perches forward,move shackles back(better,but will give a little more height),or move both.It depends on where it lines up best.
11-03-2005, 09:44 AM | #6 |
Even thought every other part will be fabed or custom on the truck I better just get some new springs, the right ones.
thanks guys
11-03-2005, 02:04 PM | #7 |
OR, have a spring shop cut and re-roll the ends of those leaf springs to the correct length.
Ken '60 GMC 3/4T 4x4 '60 GMC Suburban 4x4 '64 GMC Suburban 4x4 |
