11-02-2005, 06:29 PM | #1 |
chevy truck fan
pwr brake booster question
guys,
i am looking for a pwr brake boster assy. for my 72 chevy 1/2 ton 2wd. i called a local yard & asked for a '99 or newer brake assy. from a 1/2 or 3/4 ton p/u. they first asked me if i wanted hydralic or vacum? my first question to you guys is what is the difference & why???? i guess my second question is does anyone have any input as to why this assy. would/would not work on my truck??? and if anyone has done a similar setup on there truck & what kind of truck?? any input from you guys would be much appreciated. thanks!! rodstored-72 |
11-02-2005, 06:30 PM | #2 |
Car O'Holic
Re: pwr brake booster question
I dont know if it will work on your truck... but you would need the vacum type I would immagine.
11-02-2005, 06:40 PM | #3 | |
I am guessing the hydrolic set up is from a diesel as they have no vacuum, and or heavy duty applications. I imagine you could "make" it work, with enough time, cussing, and a big hammer but why? The 3/4 stuff works good on these and you can get the compact unit to clean up the firwall as well. mike |
11-02-2005, 09:43 PM | #4 |
I am a Referee of life.
The hydralic unit uses power from the power steering pump and is usually called a hydro boost system.They can be handy if you want power brakes and a wild cam that doesn't create enough vacuum.
The 47-present Chevrolet and GMC Truck Message Board Network,it's owners,moderators,members,and associates of any type should not be held responsible for my opinion. You can't fix stupid,not even with duct tape. "My appearance is due to the fact that "GOD" does punish you for having too much fun!" Barrett-Jackson has perfected alchemy,they make rust into gold! "You can lead a horse to water but you can't saddle a duck" "Cleverly disguised as a 'Responsible Adult' "Sometimes your Knight in shining armor is just a retard in tinfoil" |
