Old 11-02-2005, 07:22 PM   #1
hAetWagon
Schlongbed MEMBER (heh)#15
hAetWagon's Avatar
82k5 4x4 Rear main replacement
Forgive the N00biness.
I have an 82K5 that absolutely SPEWS oil.
I have never replaced a rear main in a domestic.
AM I going to have to pull the motor? or the Tranny?(based on Ease.)
I've also heard all I have to do is drop the pan.
I'm prepared to do whatever...(except pay 760.00 to have someone else to do it.)
Thanks for the responses.
hAetWagon is offline   Reply With Quote
Old 11-03-2005, 06:10 AM   #2
JIMs70GMC
user # 2756
JIMs70GMC's Avatar
Re: 82k5 4x4 Rear main replacement
The directions with the seal are to just drop the pan. Irregardless of pulling the motor the procedure is the same. Unless you pull the crank while the motor is out. i.e the top half of the rear seal still has to be slid around the crank if it is still in the block. make sense? does the motor need anything else done to it that can be done while the motor was pulled? I wouldn't pull it just for the rear seal.
1970 K25, 8' stepside bed 350/465/205 44 up front, 60 in the rear 4.10s rolling on 33" Dunlop MTs
1986 K5, 350/465/208 Dana 60/14 bolt from a cucv 36" Super Swampers TSL/SX
1983 K20 w/ CUCV axles, 350/700R4/208 sitting on 37" Goodyears
1986 M1031 6.2 diesel, TH400/NP205 locker in the rear and a LS in the front, all stock for now.....
1986 K30, 350/400/205 dana 60 and 14 bolt. I kept the drivetrain. Body/bad and chassis are gone.
1981 K30, 350/465/205 dana 60 and dually 14 bolt. Has a G80, and a flat bed. Going to replace the flat bed.
1985 K20, 350/400/208 10 bolt and SF 14 bolt. I wonder where I can find some 1 tons. Hmmmmm
JIMs70GMC is offline   Reply With Quote
Old 11-03-2005, 12:57 PM   #3
hAetWagon
hAetWagon's Avatar
Jim, Once again you just made my day.
Damn, that's a lot easier than in my Supra.
