Old 11-02-2005, 09:41 PM   #1
4tiresngas
An American Soldier
4tiresngas's Avatar
Question Cuts Out When I Put Pedal to Floor
Okay, I have a 69 SWB Step with a 87+ 350 with 350 auto. It has HEI. I have replaced the plugs...gapped .045, replaced the rotor, cap, wires, and vacuum advance. I set the timing to 8 degrees advanced. The idle is around 850. It cranks as soon as you touch the key and runs smooth. In park, I can floor it and the engine sounds fine. When I'm driving it and push the accelerator quickly, it bogs down. I can accelerator slow/smoothly with no problems. The carb is a 4-barrel quadrajet (rebuild)...less than 6 months old from AutoZone.
Do you think it is the vacuum going to the vacuum advance or something else?
Dan
dan.brue@us.army.mil
4tiresngas is offline   Reply With Quote
Old 11-02-2005, 10:02 PM   #2
llegos
Re: Cuts Out When I Put Pedal to Floor
i recently experienced a similar problem I have a rebuilt Q-jet. I can floor it like 97% and all will be fine. But, i floored it all the way, and it bogged down and kinda acted a lil wierd. All the rest runs fine. Just kind of wierd if u ask me
-Steve
llegos is offline   Reply With Quote
Old 11-02-2005, 10:02 PM   #3
wink_tim
wink_tim's Avatar
You might try a little more advance on you're timing, say 10-12 degrees. Its free to try.
67 SWB
wink_tim is offline   Reply With Quote
Old 11-02-2005, 10:44 PM   #4
Boog
laying low
Boog's Avatar
It's possible the secondary air valve is opening too fast when you matt it. Even though it's a store bought rebuilt don't mean anything. If that air valve opens too fast it can cause it too sort of fall on it's face. A good shop manual will have pics and tell you in detail how to adjust the spring on the secondary air valve to help dial it in to your application. Most likely only 1 turn or less to tighten the spring will make a considerable change. Tightening the spring will delay the opening of the secondary air valve thereby taking some of the bog out of it. A quadrajets secondary bores are huge!
Boog
69 Chevy stepside, 358/T350, 4.11 posi, 4.5/4 drop, rallys, poboy driver
primer is finer
91 Chevy sportside, Tahoe, Yukon & GMC Crewcab All GM..'nuff said.
Old 11-02-2005, 11:16 PM   #5
69TowRig
This might sound basic, but check the fuel filter.
-Chris
Building a stripper, one part at a time: 1969 K5, 307, 3spd, 3 seats, hard top. Added Pwr Discs, Pwr Steering, Aux Battery, T-case Skid, Lighted Sidemarkers, HEI, Lock-Right Diff, ECE Class IV Hitch, 32" MT/Rs. Parts to Install: Hand Throttle, Console, Tow Hooks, Dual Horns, AM-FM, Dealer Swing-Away Tire Carrier, Gas Tank Skid.
Also building a 1950 Willys CJ-3A and off-roading a 2001 Nissan Frontier on 1-Ton Portals...
69TowRig is offline   Reply With Quote
Old 11-02-2005, 11:36 PM   #6
shifty
Questionable
shifty's Avatar
If I've got anything up for grabs, it'll be here: 7-hole gauge cluster for a 67-72 p/u FREE (link)
I can't check the forum daily. If I don't reply to you within 24 hours, drop me a PM! I'm (hopefully) still alive and will reply faster to a PM.
shifty is offline   Reply With Quote
Old 11-02-2005, 11:50 PM   #7
Check filter first.Then,could be getting too much fuel,sticking float,rich adjustment...
Old 11-02-2005, 11:56 PM   #8
jhow66
jhow66's Avatar
Easy way to check if it is the secondarys opening to soon is to tie the air valves so they will not open.
56 Chevy Bel-Air 2dr. HT (purchased new)
71 Chevy Cheyenne SWB PU (502HO)
65 GMC short bed step--work in progress and my gofer
jhow66 is offline   Reply With Quote
Old 11-03-2005, 12:22 AM   #9
llegos
its not the fuel filter/carb adjustments because last week i took it in to my mechanic(he tunes street/strip muscle) and he got it basically perfect. I may have to look into the seccondary air valve. Also, quick question, what is the CFM of a stock 4bbl q-jet?
-Steve
Old 11-03-2005, 08:19 AM   #10
780,iirc.
Old 11-03-2005, 10:54 AM   #11
MrC1
Dork For Days
MrC1's Avatar
I saw a place that listed Q-jets for cars rated at 770 cfm and trucks at 800 cfm. Guess there were minor differences between the models.
If you're able to go 97% throttle w/o bog problems, I'd check to make sure your throttle cable isn't trying to rip the arm off the carb by pulling too far. You could be torquing it out of wack. Just a thought.
The tension spring on the secondaries only has one turn of total travel (at least mine does). A small adjustment might be all you need, but it sounds like you've already had an expert look at it.
1972 C20, 402/700R4 - My first classic truck, bought in September 2005. 85% transformed from "Farm" to "Cool" status!
1970 Dodge Challenger 440, 4sp (my other toy) 12.67 @ 117 MPH, with a pathetic 2.022 60'
2007 Dodge Charger SRT-8
2008 Cadillac CTS
All-American garage, baby!
MrC1 is offline   Reply With Quote
Old 11-03-2005, 01:11 PM   #12
truckster
truckster's Avatar
I'd check the secondary adjustment as well. I had the same problem when I first installed my rebuild Quadrajet on my 455. It only takes a little bit of fine tuning to get it right where you want it.
I have sworn upon the altar of God, eternal hostility against every form of tyranny over the mind of man. - Thomas Jefferson
truckster is offline   Reply With Quote
Old 11-03-2005, 07:09 PM   #13
4tiresngas
An American Soldier
4tiresngas's Avatar
Okay, I was off the Net for a couple of days. I failed to mention that I did change the fuel filter also. I'm not familiar with the secondary adjustment. Anyone have pictures to show me. I know where the idle adjustment is and the two air/fuel adjustment screws and that's about the extent of my knowledge. Again. appreciate all the input.
Dan
Old 11-04-2005, 12:30 AM   #14
jhow66
jhow66's Avatar
this might help: (allen screw underneath-loosen this just enough so you can turn other slot head screw-tighten slot head screw about 1/4 turn-hold in this position and tighten allen screw. ) Try it out if not right tighten 1/8 turn each time. (P.S. there is no written warrenty on above advice )
Old 11-04-2005, 01:59 AM   #15
Cat Fuzz
My son, my joy.
Cat Fuzz's Avatar
No one has mentioned the accelerator pump dumping too much fuel?
'69 Chevy 3/4 ton, 327cid, Carter AFB, Edelbrock intake, HEI, TH400.
Founding member of the No Money To Spend On My Truck Club.
When your at Home Depot, you WISH you had gotten an 8 foot bed!
Cat Fuzz is offline   Reply With Quote
Old 11-04-2005, 11:24 AM   #16
MrC1
Dork For Days
MrC1's Avatar
Not likely if it runs okay at all but WOT.
2008 Cadillac CTS
