Old 11-03-2005, 12:40 AM   #1
jaydog1291
My Truck won't start
Hi everyone. This is my first post. I have a unique problem. I own a 63 C-10 Chevy pick up. Its runs great, however when it gets hot say after 10 or 15 minutes of running, If I turn it off it wont start back up until it cools down some. Any ideas why this could happen? I have a Small block Ceevy 350 under the hood. Thanks in advance. Jason
jaydog1291 is offline   Reply With Quote
Old 11-03-2005, 02:53 AM   #2
AesC10s
Chevy truck addict
AesC10s's Avatar
Re: My Truck won't start
Sounds like your having a problem with vapor lock. do you have headers? check and see if your gas line is close to your headers/exuast anywhere cuase that might be the problem if its to close. you might wanna det this moved to the engine form u will get more response there.
Aaron
AesC10s is offline   Reply With Quote
Old 11-03-2005, 07:47 AM   #3
Frizzle Fry
Frizzle Fry's Avatar
Welcome. Won't start as in won't crank, or won't fire?
Frizzle Fry is offline   Reply With Quote
Old 11-03-2005, 11:33 AM   #4
jaydog1291
THE TRUCK WILL CRANK BUT JUST NOT START TILL IT COOLS OFF A BIT. oNCE IT COLLS OFF IT STARTS RIGHT BACK UP NO PROBLEM. i DO NOT HAVE HEADERS. YET ANYWAY. ANY IDEAS? Jason
Old 11-03-2005, 06:05 PM   #5
Frizzle Fry
Under the hot-no-start condition, spray a little starter fluid down the barrels and see if it trys to fire. If you get a momentary kick, then you have a fuel issue when hot. If not look at the ignition side (coil going south maybe).
