Old 11-03-2005, 11:19 AM   #1
shelby987
shelby987's Avatar
I6 Tbi??
I have been searching high and low, and have yet to come across anything or one who can give me any information about putting a tbi setup on an I6 chevy....250 specifically......short of building a megasquirt stand alone fuel management system and programming the whole thing by hand, does anyone know of any companies that have done this (or people that may have already setup something like this?)
I have read a bunch of the holley information, but it all states v6 and v8 applications, is this going to be compatable? Any direction would be appreciated....can I retrofit a v8 computer.....any companies specialize in this tuning?
Someone said I can use a 4.3 ecu and that should be 'good enough' because they are similar displacements.....but displacement does not the engine make, was hoping for a little insight from someone more knowledgeable.
Yes, I did check inliners.org......was unable to find anything, if i missed it, please let me know
shelby987 is offline   Reply With Quote
Old 11-03-2005, 02:02 PM   #2
Re: I6 Tbi??
These are the six banger folks and the have what you seek.
http://cliffordperformance.net/
Palf70Step is online now   Reply With Quote
Old 11-03-2005, 05:35 PM   #3
Ochre
Re: I6 Tbi??
The problem with the I6 and TBI is that the 4.3 V6 distributor will not drop in the older I6 chevy motor without some serious machining and/or redesigning. All is not lost though, you could easily weld the dizzy on the 250 and disconnect the vacuum advance so it doesn't advance/retard anymore, and wire the HEI trigger to a TBI ECM. All TBI ECM's use the dizzy to trigger the injectors and keep track of engine speed, and accordingly adjust when the coil is fired to change the advance/retard.
On a related note, the megasquirt EFI unit doesn't control spark unless an additional module (megajolt) is added. I've heard of/seen people welding the dizzy to use the 1227747 ECM (87-91 TBI Trucks, blazers, burbs and some cars) on different non-GM cars, including porsche and nissan.
Ochre is offline   Reply With Quote
Old 11-03-2005, 06:09 PM   #4
.030over
Junior Member
.030over's Avatar
Howell engine development
Check with these guys. They set me up on my 383 and they do jeep I6 stuff. I bet they have done a Chev I6 as well.
http://www.howell-efi.com/ck_tbi_index.html
Scott
'67 SWB big block project
'85 C60 school bus motorhome conversion
.030over is offline   Reply With Quote
Old 11-03-2005, 06:12 PM   #5
Jason915
Re: I6 Tbi??
Why not just use the Holley Pro Injection its just an aftermarket TBI
1971 GMC K1500 SWB Fleetside, 4" skyjacker softride and, 14 Bolt FF, HD Dana 44 4.10's
1970 K5 TBI conversion lifted etc SOLD
1968 C20 camper truck SOLD
“To ban guns because criminals use them is to tell the innocent and law-abiding that their rights and liberties depend not on their own conduct, but on the conduct of the guilty and the lawless.” Jeff Snyder
Jason915 is offline   Reply With Quote
Old 11-03-2005, 09:17 PM   #6
djracer
djracer's Avatar
Re: I6 Tbi??
Yes call Troy Brown at Howell! He's the man on TBI!
Kevin
Special Thanks to All who have helped on the TRUCK!
My Pass Time Show http://s129.photobucket.com/albums/p...Chapter1-0.mp4
So Far my best Times are:
Motor only:
6.44 1/8 @ 104.13
10.39 1/4 @ 125.83
Nitrous Times:
5.785 1/8 @ 118.65 with a 1.336 60ft
9.168 1/4 @ 142.58 with a 250 shot dead out of the hole!
djracer is offline   Reply With Quote
