70+ ( Old Skool Club )
![]() Join Date: Nov 2003
Gas Filler Door
I've seen a few threads where members have talked about a marker lite gas filler door that they got from Kennys parts. I cant seem to find a web page or anything about Kennys as I'd really like to see what that door is all about cause I have an ECE gas tank to put on my truck and I'd like to have the filler behind the marker lite.
1972 C10 Custom/Deluxe 613 Highlander 406/700R4 1999 White Tahoe LS 4x2 with Z56 Police Package 1992 K1500 GMC Suburban Members I have personally met: MusicMan70 - HeavyD - ChewyChevy67 - StingRay -71SWB4x4 - 67 Burb - DeadheadNM - too much stuff - bc65 - das601 " Circumsatances Do Not Change Responsibility " " The Sky is not the Limit, Your Mind is." Marilyn Monroe .. RIP Charlie Watts 1941 - 2021 |
Gone Fishing
Re: Gas Filler Door
There was a thread on here awhile back on how to do the sider marker gas door conversion. Can't seem to find it to give you the link though. I'm sure somebody here will find it and help out.
68 Chevy Short Fleetside LSX Swap Under Way 3.73 posi 2.5/4 drop ![]() 2022 Hyundai Tucson Limited 2019 Chevy Traverse Redline Edition Wifes Ride Build Thread http://67-72chevytrucks.com/vboard/s...=1#post3483616 |
![]() ![]() Join Date: Jul 2002
Re: Gas Filler Door
http://www.kennystrucks.com/
I don't see it mentioned on his online page. You maye have to call them about it. There is some thread in the FAQ section about doing this
Bill 1970 Chevy Custom/10 LWB Fleetside 2010 Toyota Tacoma PreRunner SR5 Double Cab - DD Member of Louisiana Classic Truck Club (LCTC) Bill's Gallery Life isn't tied with a bow, but it's still a gift. Live simply. Love generously. Care deeply. Speak kindly. Leave the rest to God! Last edited by Palf70Step; 11-03-2005 at 01:50 PM. |
#4 | |
Re: Gas Filler Door
1972 C10 Custom/Deluxe 613 Highlander 406/700R4 1999 White Tahoe LS 4x2 with Z56 Police Package 1992 K1500 GMC Suburban Members I have personally met: MusicMan70 - HeavyD - ChewyChevy67 - StingRay -71SWB4x4 - 67 Burb - DeadheadNM - too much stuff - bc65 - das601 " Circumsatances Do Not Change Responsibility " " The Sky is not the Limit, Your Mind is." Marilyn Monroe .. RIP Charlie Watts 1941 - 2021 Last edited by Already Gone; 11-03-2005 at 02:15 PM. |
Re: Gas Filler Door
I just saw a thread with picts and all, but I do not remember it being a kit though. It was picts and instructions how to use an S10 filler neck a pice of hose and the door from the S-10. From what I remember it was the whole filler assembly from the S10 and you affix the marker light to the filler door (After you remove the S10 door from the hinge) and trim the filler assembly. I know this does not help, but it is not a kit, seach for filler door or hopefully someone will be able to attach the link here.
#6 | |
Re: Gas Filler Door
FOUND IT!! http://www.classicheartbeat.com/mark...t_gas_door.htm Here are the two links, I just searched for s10 filler conversion marker light, man I love that search option. Good luck I am thinking of trying this myself! Last edited by 70rs/ss; 11-03-2005 at 03:09 PM. |
Re: Gas Filler Door
Here's a link to the one I want. Hope this helps?
http://www.classicheartbeat.com/mark...t_gas_door.htm ![]() ![]() ![]()
![]() ![]() ![]() LIFE AIN'T EASY WHEN YER FAT AND GREASY! GMC= Got More Class! ![]() ![]() |
More Cowbell....
Re: Gas Filler Door
Be advised that the install that the link points to is on a 4X4 with a 3" body lift, which makes running the rubber filler hose a lot easier. For a 2X truck, or one without a body lift, it is a little tricky, but completely do-able.
I did it on my stepper (which is way easier than a fleet side), and I love it.
There once was a member from Puckett.....Who ( fill in the blank blank blank ) bucket |
member #16
![]() Join Date: Dec 1999
Re: Gas Filler Door
Heres some detailed instructions. Have fun. John
http://67-72chevytrucks.com/vboard/s...ad.php?t=77104
john http://67-72chevytrucks.com/vboard/showgroups.php board vendors ![]() http://www.flickr.com/photos/1745471...7602865984234/ |
