soon to be bagged64sub
Will an 85 rearend fit under a 69 swb?
Is it wider or shorter?
1969 c-10, bagged, Zd, 20" Boyds SOLD! 1964 Suburban COMING SOON ![]() 1965 c-10 long bed 1993 Sierra x-cab 1999 tahoe-4/5 on 22s 2005 Chevy work truck |
![]() Join Date: Jun 2002
Re: Will an 85 rearend fit under a 69 swb?
It is wider, but not by much. I put one under a 64 chevy truck once and it fit fine (well, after I cut off the brackets and welded the trailing arm style brackets to the housing, you'll also need a provision for the panhard bar)
Good luck, Rg
Roger '68 Short step - https://67-72chevytrucks.com/vboard/...d.php?t=849675 '69 ('70?) 2wd Blazer '70 GMC Jimmy 2wd '73 Firebird - https://67-72chevytrucks.com/vboard/...d.php?t=853203 |
Im 4 linking it so no problem there, I just hope my wheels will tuck.
HOW WIDE IS WIDER ? Thinking about a swap like this myself.
I'm thinking it was .75" each side (1.50" total) but that's been 15 years ago. You may be able to post in the later forums and get one of those guys to take a measurement for you.
Rg
