Old 11-03-2005, 05:42 PM   #1
bobs86silv
bobs86silv's Avatar
Wiring harness interchangability??
I have a full wiring harness from a 67 chevy. My uncle has a 65 chevy. Both trucks came with a 283 and four speed. His whole wiring deal has been chopped up pretty bad. Will the harness from my 67 hook to his 65?? Is the plug on the firewall the same? How about the regulator hookups?? Could I just swap the harness, even if I had to do some changes on wires and ends??
thanks
robert
86 Silverado SWB 350/350/3.08 9.7-1 Forged pistons Eagle Rods Eagle Crank Zero Deck Balanced Blueprinted 180cc DART Heads Roller Rockers RPM Intake Demon Carb Flowtech Headers 400HP/400TQ
bobs86silv is offline   Reply With Quote
Old 11-03-2005, 07:22 PM   #2
chevy283
chevy283's Avatar
Re: Wiring harness interchangability??
im pretty sure that 65 wiring will not plag up to 67. the 65 dosen't have much wiring go to this site for a wiring diagram. http://pages.zdnet.com/64moneypit/id12.html
65 c10 tore apart
70 c10 305/350th
chevy283 is offline   Reply With Quote
Old 11-04-2005, 01:33 AM   #3
Hilandr451
Hilandr451's Avatar
If it were me, I'd pick up a manual for the '67, flip to the wiring diagram and compare it wire for wire with the '65 wiring diagram on Dave's web site.
I've got a hunch that they'll work. If I remember right, there were no significant changes to the wiring until 1968. But don't take my word for it, eyeball the two diagrams & check for blade positions in the connectors, wire colors & where they connect to.
Another thing you can do is physically compare the connectors of the two by seeing if you can plug the front harness from one truck into the other truck's firewall connector and vise versa.
Good luck!
Greg Smith a.k.a. "The Highlander"
1966 C20 Custom Camper, 2017 Chevy Silverado 1500
Highlander's Project Pics
Highlander's web site: www.6066ChevyTrucks.com
Hilandr451 is offline   Reply With Quote
