Old 11-03-2005, 10:49 PM   #1
bigblockc10
bigblockc10's Avatar
72 2wd Blaser spindles will the y work on?
Hey I sure hope I didn't jump the gun again here, but these 2 inch drop spindles I found on Ebay were going cheap 142.00 new so I bought em.
I didn't have time to check the interchage as i was at work when I bid and won so can you guy's give me some insight.
they are for a 72 2wd Blaser will they fit on a 71/72 disc brake suspension out of a C10.
1970 C10 Stepside (soon to be a 68
w/PS/PB/S&W back-half narrowed F**D 9inch w/Discs)
66 427/435 corvette motor (hopefully 871 Blower)
66 M21 4 speed (swapped in a built TH400)
31/16.5/15 Mickeys (soon to be 29.5X18.5X15 MT)
1972 C10 Stepside Pro-Street
1988 bed
3" Top Chop
Custom Red Pearl paint w/overlapping Ghost Flames
P/S P/W P/B P/DL P/door open
Everything Shaved
Frenched antenna
461CI BBC BDS Blower 1100 Dynoed HP
TH400 Super Heavy Duty
Full Back-Half
Narrowed 12 Bolt 4:10
bigblockc10 is offline   Reply With Quote
Old 11-03-2005, 11:07 PM   #2
jsbgump
Gone Fishing
jsbgump's Avatar
Re: 72 2wd Blaser spindles will the y work on?
They should work with no problem
68 Chevy Short Fleetside LSX Swap Under Way 3.73 posi 2.5/4 drop Frame of resto has been started
2022 Hyundai Tucson Limited
2019 Chevy Traverse Redline Edition Wifes Ride
Build Thread
http://67-72chevytrucks.com/vboard/s...=1#post3483616
jsbgump is offline   Reply With Quote
Old 11-03-2005, 11:07 PM   #3
John Fabris
TOTY 2006
John Fabris's Avatar
If they are correct for a 72 2wd blazer, they will work on 71-72 1/2 ton truck/blazer/suburban.
They should also work on 67 - 70 but you will have to change ball joints and outer tierod ends to 71-72. If I am incorrect, someone please add the correct info...
John Fabris
67 C10 SWB
John Fabris is offline   Reply With Quote
Old 11-03-2005, 11:19 PM   #4
bigblockc10
Thumbs up Re: 72 2wd Blaser spindles will the y work on?
Thanks Guy's this board is absolutely indespensible.
Now just get lowered springs,finish the prostreet frame(building myself),bodywork,parts,parts,paint and I'll almost be finished!!
Thanks again!!!!
1988 bed
3" Top Chop
Everything Shaved
Frenched antenna
Full Back-Half
Old 11-04-2005, 12:58 AM   #5
Deuce
Deuce's Avatar
You will also need the conversion adjusting sleeve from someone like CCP. The 71/72 tierods are a different diameter than the 67-70.
I know what your thinking.......I have ESPN.
Sometimes it's easier to do things the hard way.
Fesler Built 1968 Chevy C10....Must resist the urge to mess with it!!
Deuce is offline   Reply With Quote
Old 11-04-2005, 11:26 AM   #6
ChevLoRay
Old Skool Club
ChevLoRay's Avatar
My dropped spindles are from Early Classic and they use the stock tie rod ends. But, as stated in the quote, some others will require the conversion pieces, as listed.
Good price, though.
Member Nr. 2770
