Old 11-04-2005, 10:39 AM   #1
shelby987
shelby987's Avatar
electric fuel pump and a carb
The engine I bought was apparently originally built to be 'happy' in the high RPM's and the PO didn't want to run the motor with the original mechanical fuel pump, so he bought an electric pump.....if I use it for the install, do I need to run a return line to the tank like a fuel injected setup?
Also, can anyone tell me how to hook up an electric fuel pump? I know I need a paper filter before the pump, and a screened filter after it (right before the carb I am told is the best location), but other than that, I need direction, I know nothing about electrical.....how do I put juice to this bad boy?
shelby987 is offline   Reply With Quote
Old 11-04-2005, 07:46 PM   #2
bejay
Re: electric fuel pump and a carb
depends on the pump you are using it may or may not need a return line would have to know more about it to give you any info if you dont know the specs you may be able to get the info from the manufacturer if it puts out low pressure under 10 psi then you shouldnt need a return line.
I would just stick a mechanical pump on it if possible and not even bother with installing an electric pump.
bejay is offline   Reply With Quote
Old 11-04-2005, 07:50 PM   #3
cdowns
cdowns's Avatar
you shouldn't need a return line but i would highly recomend a pressure regulator//most applications you're alot better off with a standard mech fuel pump
Old 11-04-2005, 08:26 PM   #4
kelsfine69
18 Till I Die
kelsfine69's Avatar
I got a Holley blue pump with a filter before the pump, mounted under the cab. Then my Holley regulator is mounted right beside my carb( duel feed) and a gauge right beside. Run a ignition "on" wire to the pump and ground it. On when you turn the key and off is off. Its not a daily driver but is very reliable. I can post some pics if ya want.
2011 GMC Acadia
1969 GMC BBC LS7
2007 GMC Crew Duramax
1987 Camaro Iroc 350 Tuned Port Injection
42000Km
1987 Chevrolet Silverado 350 TBI
1987 Chevrolet Silverado 350 TBI(yes 2)
Take me drunk, I'm too home...
kelsfine69 is offline   Reply With Quote
Old 11-05-2005, 09:38 AM   #5
shelby987
shelby987's Avatar
Pics would be helpful.....you don't need a fuse for the pump at all?
Old 11-05-2005, 03:34 PM   #6
kelsfine69
18 Till I Die
kelsfine69's Avatar
Here you go. Yes you should fuse it...prob a 20-30A. as you can see I mounted mine right under the tank with the filter before the pump. They sell the filter at NAPA or any parts store. Its made by Fram but a lot of other companies sell it under their name, and it takes a fram filter so its easy to find. Also I used a brass fitting to link the two units together before I mounted them. Then I used braided lines and fittings from Russell to plumb the rest. I am thinking about swapping out the Holley regulator for a Areomotive one, I think its a better regulator.
2011 GMC Acadia
1969 GMC BBC LS7
42000Km
Old 11-05-2005, 04:02 PM   #7
71Dragtruck
71Dragtruck's Avatar
I'd just run a mechanical, I run a Victor series with a Moroso hollow rod and spin it to 6500rpm all the time had it for years now works great, puts out 130gph at 14psi, Edelbrock rates it good for 900hp. On my nitrous side I run a Holley blue electric, with a dead end system but it only stay's on for 20 sec at a time, enough to stage run the 1/4 and then off. If you want to run a electric on the street and have a reliable system, go for a flow through pump with a return style reg. The fuel will cool the armature of the pump as it runs, and the return style reg will keep the amps down and be easier on the pump. Run a pre-filter before the pump and then a finer one after the reg of just before. Run a size larger line on the suction side, sizer depends on HP and length of line.
Speed is just a matter of money, question is how fast can you afford to go?
8.95@148.97mph all motor haven't tried bottle yet
Sponsored by:
Getz Oilfield Consulting
Hard Candy Customs
71Dragtruck is offline   Reply With Quote
Old 11-06-2005, 12:25 AM   #8
tiltbed69
Your average automotive electric pump should put out between 4-5 lbs pressure,which you don`t need a regulator or return line....Hi Per pumps put out anywhere from 7- 15 lbs pressure....which should be regulated to aprox 6 1/2 lbs ,depending on the CFM and CID of motor....electric pumps are pusher pumps..IE place as close to the fuel tank as possible (but NOT in the cab if used on a 72 down truck)...Ideal set up is to have a wire run from a oil pressure guage,with a push button over ride.In case of an accident motor stops...pump stops.And allways as with ANY electrical assesory ALLWAYS put the proper amp fuse in line as close to the power sourse as possible...Sid
tiltbed69 is offline   Reply With Quote
Old 11-06-2005, 12:47 AM   #9
kelsfine69
18 Till I Die
kelsfine69's Avatar
Yes I have a Pro-lite with a 15 pound cut out switch, any thing under that I SHUT HER DOWN!!
2011 GMC Acadia
1969 GMC BBC LS7
42000Km
Old 11-06-2005, 11:26 AM   #10
427V8
427V8's Avatar
If you run an electric pump there should be an oil pressure switch to shut off the pump when the engine stops.
It's a safety thing, so in a crash the pump will stop if the engine does and not keep pumping fuel all over you...
427V8 is offline   Reply With Quote
