Old 07-08-2002, 11:19 PM   #1
Mountain Man
In Cab - Gas tank sending unit
My new gas tank sending unit is coming tommorow. Before I start to remove the old sending unit and put the new one in, I thought I would ask the experts if there is anything tricky I should know.
I assume that you unhook the wire, tap on the locking ring to the left, unhook the fuel line, and pull it out. Am I missing anything???
72 C10 Cheyenne Super
Full trim
Factory tach dash
A/C dash
Factory tilt
350 / 350 power train - with Edelbrock components.
Mountain Man is offline   Reply With Quote
Old 07-08-2002, 11:42 PM   #2
Longhorn Man
its all about the +6 inches
Longhorn Man's Avatar
Yeah...no smoking.
Make sue you are under 3/4 tank of fuel, and do this in the driveway...not the garage. The fumes will kick your @ss. Try to get you hands on a brass drift, or an alluminum bar to beat teh ring off with. Less chance of sparks.
Old 07-09-2002, 05:03 AM   #3
'68OrangeSunshine
'68OrangeSunshine's Avatar
Disconnect the negative Batt terminal first, too.
Old 07-09-2002, 07:19 AM   #4
Longhorn Man
That part was implied....only cuz i forgot it.
Actually, that really isn't needed. The brown wire is a negitave, and runs off of reduced voltage too.
