Old 11-04-2005, 03:58 PM   #1
71jimmy
71jimmy's Avatar
Hardtop Weatherstipping ?
Just ordered new weatherstripping for my hardtop were it mounts on the bed rails and the top of the windshield. Do you guys glue the weatherstipping to the hardtop? Or does the weatherstripping just lay in between? If it's glued, anyone know what the factory used? Rubber Cement? Silicone?
'71 Jimmy, 350, SM465, NP205, 2in Tuff Country lift, 33s on rallies, TBI, softtop and hardtop
"If life was fair you'd be able to afford one of each and a garage large enough to house them all."
71jimmy is offline   Reply With Quote
Old 11-04-2005, 04:34 PM   #2
bouncytruck
SKINNY TIRES RULE!
bouncytruck's Avatar
Re: Hardtop Weatherstipping ?
I just used weather strip adhesive (rubber cement). From pealing off the old stuff, it appears the factory used something black. It may have even been an adhesive strip or tape of some kind.
I had to use some Gorilla Snot (super weatherstrip adhesive) in a few places because the rubber cement wasn't holding well enough.
bouncytruck 1972 K5
The Hauler 1994 K1500 Suburban
The Daily2010 Kia Soul
Wife's Ride2014 Fiat 500L
bouncytruck is offline   Reply With Quote
Old 11-04-2005, 05:10 PM   #3
Baketown Scotty
Junior Member
Baketown Scotty's Avatar
I have been using the weatherstip adhesive from LMC around my doors. Have not got to the hard top yet. Appears to be holding real good.
Baketown Scotty is offline   Reply With Quote
Old 11-05-2005, 09:26 AM   #4
72CSTC5
72CSTC5's Avatar
Try the 3M Super Weatherstrip Adhesive in black. The one Bouncy mentioned. Apply it to the top and let it tack up first and then install your gaskets to the top.
72CSTC5 is offline   Reply With Quote
Old 11-07-2005, 01:21 PM   #5
71jimmy
71jimmy's Avatar
Thanks everyone!
Old 11-08-2005, 12:38 AM   #6
BobbyK
BobbyK's Avatar
Location: Petrolia,Ontario,Canada but working in Port Huron,Mi.
I used this stuff.Works great.
71 blazer,350SBC,approx.375HP,700R4,factory GM TPI.Dual electric fans,33x12.5x15 ATR on stock suspension.
Petrolia,Ontario,Canada but working in Port Huron,MI.
See ALL my Blazer pic's HERE
BobbyK is offline   Reply With Quote
Old 11-09-2005, 10:42 AM   #7
HatGuy
HatGuy's Avatar
BobbyK,
Where did you get it?
Joe Peters the HatGuy
72' K5 Highlander
My Daily Driver
http://www.pbhats.com/BLAZER/index.html
HatGuy is offline   Reply With Quote
Old 11-09-2005, 12:05 PM   #8
bouncytruck
SKINNY TIRES RULE!
Yeah know, I thought about using some of that stuff, but as I recall, it is kind of messy. I also wasn't sure if it would harm the rubber, but I guess I didn't really think it through. Maybe next spring when I put the soft top back on, I'll redo the rubber around the doors with that stuff.
bouncytruck 1972 K5
Old 11-10-2005, 10:43 PM   #9
BobbyK
BobbyK's Avatar
HatGuy.I got it at my local auto body supply store.
