Old 11-04-2005, 08:13 PM   #1
Jebb1978
Jebb1978's Avatar
Rear axle flip kit Questions
Hello again fellows,
I am consittering the DJM flip kit and 3" drop spindles. First question is, since I did the shackle kit the truck is sitting level. With the shackles and flip kit is the rear going to end up lower than the front if I do 3" spindles?
Also I am sure this question has come up in the past but, do I need to C the frame for the flip kit? It looks like it sure would be close to me.
Thanks Guys,
Shawn
1959 GMC project
Jebb1978 is offline   Reply With Quote
Old 11-04-2005, 09:22 PM   #2
SCOTI
SCOTI's Avatar
Re: Rear axle flip kit Questions
Yes. You'll need to bring the front down more.
If you run the shackles w/the flip kit it will hit the frame on alot of bumps & dips but you can drive it w/o the c-sections. I highly recommend installing the c-sections because you'll only have 1~1.5" max between the frame & rear end housing.
67SWB-B.B.RetroRod
64SWB-Recycle
89CCDually-Driver/Tow Truck
99CCSWB Driver
All Fleetsides
@rattlecankustoms in IG
Old 11-05-2005, 12:17 AM   #3
Jebb1978
Jebb1978's Avatar
Question Re: Rear axle flip kit Questions
1)Okay then how low are we talking? Should I just replace the stock shackle? I don't want to be scraping my cross member on speed bumps. It sounds like this may be lower than I want to go.
2)I was thinking of just cutting out a C in the frame and then welding a piece of pipe in where it was cut out. Are you talking more than that? I don't want the rearend hitting the frame at all. I would do the extra work to keep that from happening. Again, should I just pop those original shackles back on and then flip the rear end? would that make it sit level? If I did would I still hit the frame? Sorry I can't just be simple Scoti, I really do appreciate your help.
I actually emailed my question to truckshop.com and have yet to hear back.
1959 GMC project
Old 11-05-2005, 01:34 AM   #4
SCOTI
SCOTI's Avatar
....Should I just replace the stock shackle? I don't want to be scraping my cross member on speed bumps
My truck has the spindles + a coil whacked off... no crossmember scraping in 3yrs. Has my exhaust or a-arm ever hit? A-arm once, exhaust a couple of times.
....should I just pop those original shackles back on and then flip the rear end? would that make it sit level? If I did would I still hit the frame?
A flip kit will typically net about 5-6" of drop (5 leaf spring pack/5"; 8-leaf pack/6"). Take a tape measure outside & measure directly above your axle C/L to the frame. Subtract the 5 or 6" & if the measurement is 2" or less, you want a c-notch.
You already have the shackles so my vote is do the flip kit w/the current shackles. If you want more drop up front.... you can trim the coils. If the drop is too much out back.... swap back to the stock shackles. You won't be spending any more money, just investing a little more effort to get it right. The flip kit by itself has enough clearance to not need a c-notch unless the truck is loaded down.
....I was thinking of just cutting out a C in the frame and then welding a piece of pipe in where it was cut out. Are you talking more than that? I don't want the rearend hitting the frame at all....
A simple c-notch like the welded section of pipe you mentioned would work fine. There's no need for anything more because you'd have to start cutting up the bed floor next.
I hope this helps . . ....
67SWB-B.B.RetroRod
64SWB-Recycle
99CCSWB Driver
All Fleetsides
Old 11-05-2005, 02:13 AM   #5
Jebb1978
Jebb1978's Avatar
This helps a lot! Thanks for your time once again.
Is there any chance I could get some pics of your 74 on here to see what we are looking at as far as end result?
1959 GMC project
Old 11-09-2005, 09:45 PM   #6
corn
Ive got a flip kit & shackles. There is 1 1/2" between the frame & housing. I will be doing a notch on mine before it hits the road but I did jump up & down on it with no shocks & it didnt hit. Im sure a big bump would make it thump pretty good though. Good luck with it...corn
corn is offline   Reply With Quote
Old 11-10-2005, 01:39 PM   #7
Captkaos
www.73-87chevytrucks.com
Captkaos's Avatar
It ain't pretty, but this is my truck with 4" in front and a 6" flip in the rear. It is sitting on 255/55/17's.
I recommend getting the C-notch also.
Chris Lucas
1973 Chevy C-10
1978 GMC Jimmy (2WD) - SOLD
1987 R10 twin turbo LS
1991 R3500 SRW CrewCab
Captkaos Customs
Old 11-11-2005, 01:12 AM   #8
Jebb1978
Jebb1978's Avatar
Looks pretty to me.
1959 GMC project
Old 11-11-2005, 11:47 AM   #9
Captkaos
Captkaos's Avatar
Thanks, but it doesn't look anything near that now....
Looks more like this:
http://www.captkaoscustoms.com/images/enginemock1.jpg
Chris Lucas
1973 Chevy C-10
Captkaos Customs
