Old 11-04-2005, 08:21 PM   #1
davidh
davidh's Avatar
T5 and 283
I saw a 68' on ebay, it wasn't running but it had T5 behind a 400. I'm sure it will be short lived. But I was thinking of putting one behind a 283-350 in a 67 to try to get some mileage and have some hiway gear. Is the one out of a S10 the one I need? It seems like the shifters are in different places for the camaro and s10. Anyone done this? The truck will only be used for light hauling.
davidh is offline   Reply With Quote
Old 11-04-2005, 08:28 PM   #2
chevybill
chevybill's Avatar
Re: T5 and 283
you need amanual from a 4.3 s-10, it is the same tranny that was put in 90's half tons except the shifter on the s-10 tranny will be at the back of the tranny instead of about the middle. i am using a s 10 tranny behind a vortec 350 - once i get the truck back together.
ongoing 1970 c 10 lwb
1994 z-28 few mods.-owned since new
1978 vette silver/grey 25th anniv. paint
chevybill is offline   Reply With Quote
Old 11-04-2005, 08:55 PM   #3
Longhorn Man
its all about the +6 inches
Longhorn Man's Avatar
Re: T5 and 283
The camaro had the stronger one with the right spline count, you'll need to probably make a custom shaped shifter, not too hard if you can cut and weld...could actually make it look good if you wanted to.
Only rated for 305 ft pounds... I would do it with a 283 or 307, but not to a 350... not if you plan on haulin/towin/hot ridding/off roading.
Camaro tranny will need a custom wedge placed under the tranny mount to make it bolt down properly, the T-5 in an F body was turned a few degrees to try and make more foot room in the car.
