How can i make my old grill shine
Is there a way that i can make my old 1969 chevy grill shine?
Recovering Truck Driver
the only way I can think of is to start sanding, start with like 180 or 200 grit paper on a D/A sander, then get some buffing compound, a buffer, and a squirt bottle full of water and go to work....I polished a set of badly nicked up fuel tanks for a Peterbilt once, took me forever, but when I was done, I could've used them for shaving mirrors.
67 K-20 350, SM465, Eaton rear, 4.56 no spin option 00 Dodge 2500 4x4, 24V cummins, 5 speed Chad South Central Nebraska |
Livin' it up.
![]() Join Date: Nov 2001
i thought i read someone on here used oven cleaner to get their grille to shine but i could be wrong so dont try it until someone verifies this
-Greg; Sold the 69 C20. It's off to a better home with more love! Now onto the 86 CUCV M1009; K5 blazer with 6.2L diesel, corp 10 bolt axles, Detroit locker in the rear, trutrac front, 3.73 gears, 35" tires. ![]() |
Oven cleaner is used to take the anodizing off the grill before polishing and reanodizing or clear coating the grill. If you polish the grill and not seal it with a quality clear coat or anodizing it will dull and need polishing all the time.
Rest in Peace Ed. Thanks for all the good times. |
Woody Wax
Woody Wax--
Seems the stuff can eat corrosion off aluminum. Boaters swear by it. |
#6 | |
![]() Join Date: Oct 2001
Re: Woody Wax
0000 Steel wool works wonders
1970 GMC Custom 1500 SWB 307/TH350 3.73 Positrac |
67-72 Addict!
I had www.qweststar.com do this grille. Awesome job!. They even repaired minor dings. It now looks like chrome. They do not Re-anodize, so you will have to polish it from time to time. They don't recommend clearcoating either because it takes so much abuse being in front of the truck.
Jim 1970 C/10 Fleetside w/Ghost Flames Lowered 4.5" front and 4" rear (Raked) 355/350 Turbo w/shift kit 10" Redneck Performance Verter w/2500 stall Hooker Super Comps part#2808-1 Performer RPM Air-Gap 12 Bolt w/3:73 gears- Eaton Posi Comp Cams XE262 with 1.6 Crane Energizers, Road Demon 625 and Brodix IK 180 heads Last edited by 70c10; 07-09-2002 at 02:46 PM. |
