Old 11-05-2005, 12:49 AM   #1
soleeagle
soleeagle's Avatar
Drag Link
Where is a good place to get a drop drag link from? I have been looking but have not had good luck finding one. Thanks for the help.
Chuck
'85 Chevy Silverado 4X4
'91 Chevy 4X4 Suburban
http://www.cardomain.com/memberpage/545941
soleeagle is offline   Reply With Quote
Old 11-05-2005, 04:26 AM   #2
1976K5CHALET
1976K5CHALET's Avatar
Re: Drag Link
Not sure but i think super lift is one of the few who makes them.
If you have a D44 or GM10B with a 4 to 6 inch lift i recommend the raised
steering arm.
DW
Doug Wright aka K5NUTT over @coloradok5.com
Owner of http://groups.yahoo.com/group/ChevyK5BlazerChalets
Certified K5 Nut
1976K5CHALET is offline   Reply With Quote
Old 11-05-2005, 09:13 AM   #3
Yukon Jack
Post Whore
Yukon Jack's Avatar
Re: Drag Link
www.offroaddesign.com can get you one. It may not be listed on their website but the got me one when I need it for my closed knuckle Dana 44.
1970 Blazer with a 400 sbc and 4" lift
1980 Pontiac Trans Am, 455 Oldsmobile
2012 Kawasaki Concours 14
Yukon Jack is offline   Reply With Quote
Old 11-05-2005, 09:49 AM   #4
JIMs70GMC
user # 2756
JIMs70GMC's Avatar
Re: Drag Link
Skyjacker has them also, I've seen them in 4 wheel parts ads, but I don't advocate buying from them if you can support someone else, like ORD. I'd recommend the raised steering arm and/or dropped pitman arm first. The dropped drag link does nothing for bump steer, only corrects the TRE angles. They also cost more than the raised steering arm or dropped pitman arm. If you already have some steering correction and need more, cross over would probably be better.
1970 K25, 8' stepside bed 350/465/205 44 up front, 60 in the rear 4.10s rolling on 33" Dunlop MTs
1986 K5, 350/465/208 Dana 60/14 bolt from a cucv 36" Super Swampers TSL/SX
1983 K20 w/ CUCV axles, 350/700R4/208 sitting on 37" Goodyears
1986 M1031 6.2 diesel, TH400/NP205 locker in the rear and a LS in the front, all stock for now.....
1986 K30, 350/400/205 dana 60 and 14 bolt. I kept the drivetrain. Body/bad and chassis are gone.
1981 K30, 350/465/205 dana 60 and dually 14 bolt. Has a G80, and a flat bed. Going to replace the flat bed.
1985 K20, 350/400/208 10 bolt and SF 14 bolt. I wonder where I can find some 1 tons. Hmmmmm
JIMs70GMC is offline   Reply With Quote
Old 11-05-2005, 02:24 PM   #5
soleeagle
soleeagle's Avatar
Re: Drag Link
Thanks Guys, I have the raised steering arm so I will look into a drop Pitman arm instead of the drag link.
Chuck
Old 11-05-2005, 11:45 PM   #6
bigarmzz
bigarmzz's Avatar
Re: Drag Link
www.ntwonline.com
bought a gazillion things from them...they know there stuff
1987 350 TBI lowered 5/7
bigarmzz is offline   Reply With Quote
