More than 3" drop without spindles?
Is there any way I can get a little more drop in the front of my 69 without swapping out to disc brakes & installing drop spindles? Ive got 3" ground force springs now but would like to go a little lower.
Re: More than 3" drop without spindles?
smaller tires
"Trucks with Class"
![]() Join Date: Jul 2000
Tubular or stepped A arms...not my favorites, but that is what was used before dropped spindles.
That may be the way to go. Thanks PICKMUP!
![]() Join Date: Dec 1999
It has been a while since I have been in the lowering scene. But I recall that the dropped arms used a couple of methods to achieve the lowering.
A dropped spring pocket which is much the same as a shorter coil with the exception of a vulnerable hunk of metal ending up lower than the A-Arm. The other method steps up the ball-joint area. Just be carefull about any part of the arms being below the rim on a driver. A flat with no wheel on the ground make the vehicle very hard to control.
Richard 1972 K10 Custom Deluxe SWB Fleetside My build https://67-72chevytrucks.com/vboard/...d.php?t=800746 |
Out of the carpool lane.
1968 C-10 SWB, 5.7 Vortec/700R4/3.73 posi, Torch Red 1968 Camaro, 250/Powerglide, all original (No, I'm not gonna drop a 350 in it!...Jeez!) 2000 Honda VFR in the faster yellow! 2008 Husqvarna TE-610 1967 C-10 SWB 'Six Appeal'-Gone but not forgotten... |
