![]() Join Date: Apr 2000
Ever See One of These
I was looking through my assembly manual and came across this pic. It shows a cover on the duct for the cable and lever that controls the heat and defrost. I have never seen one. Has any one ever seen one. It looks like it would make a nice touch to the inside.
1970 CST/10 402,700R4,3:73 posi,AC,PS,PB,TLT,PW,Buckets with heaters |
Car O'Holic
Re: Ever See One of These
that would hmm never seen it though
From the pic it looks like it would be really easy to make with some mild gauge and a sheetmetal break. I can't really tell from the picture, does it screw in at the top anywhere?
-Chris Building a stripper, one part at a time: 1969 K5, 307, 3spd, 3 seats, hard top. Added Pwr Discs, Pwr Steering, Aux Battery, T-case Skid, Lighted Sidemarkers, HEI, Lock-Right Diff, ECE Class IV Hitch, 32" MT/Rs. Parts to Install: Hand Throttle, Console, Tow Hooks, Dual Horns, AM-FM, Dealer Swing-Away Tire Carrier, Gas Tank Skid. Also building a 1950 Willys CJ-3A and off-roading a 2001 Nissan Frontier on 1-Ton Portals... |
![]() Join Date: Jan 2004
Good eye man. Had & seen hundreds of these trucks and never seen one. Very interesting.
Intersting observation PU70. I wonder if it's for cowel models or something like that. I've never seen one either.
Unrestored 68 C-10 CST. Original 327. 4-Speed CH465. 50k or so miles. TREASURER, Drum Brake Club. |
It seeems like it`s a deflector for an Cheyane A/C model ...mebe??? Sid
![]() Join Date: Sep 2005
Was it for an overseas/export model? Some cars made for very hot climates (Africa, Middle East) came w/out heaters. A heater delete panel??
1968 Custom SWB, 327/3 speed OTC 1969 CST LWB, 402/400 1970 CST LWB, 402/400 1970 Sierra Grande LWB, 350/350 1971 Cheyenne LWB, 350/350 1972 Cheyenne Super LWB, 402/400 1972 Sierra Grande LWB, 402/400 1979 Silverado LWB, 350/350 1984 Suburban 1990 454 SS 1991 Silverado, X-cab, 4.3/5 speed Getrag 2005 Silverado Crew Cab Corvettes: 75, 77, 78, 93, 96 |
#8 | |
Where's my beer?
Cool things you find in the factory manual, some things you never knew existed.
![]() Quote:
Looked at my heater box yesterday, it has the two screwholes in the steel for that plate but obviously has never had anything screwed into it. I'm going to make one here one of these days.
Yes - I have one. Used in 40-50-60 series trucks with the pug nose. The cab is not as deep as a regular cab and so the heater box is also closer to your feet. This tin plate screws to the heater box in the holes noted above. I think it hides the heat/defrost flapper cable.
It's really not necessary for regular PU-Blazer-or Burb.
67 C-20 LWB, tilt, speed alert, vac, 454, T400 67 C-10 SWB, factory air with more to follow |
