Old 11-06-2005, 12:30 PM   #1
Botietruck
'71 chevy s.bed/s.side
Botietruck's Avatar
Carb/trans. linkage question PICS!!
On my son's '71, we were looking at the engine and realized the trans. linkage was not hooked up to the carb and a vacuum line disconnected but could not find where it hooks up, any ideas?? Can someone shoot me a few pics of the correct way they shoud be connected? The linkage does not seem long enough to connect to the holes in the carb linkage. The engine runs great other than not kicking into passing gear when you get into it.
Thanks, Bob
STILL PLAYS WITH CARS...AND TRUCKS!!
Parents! Be good to your kids...they get to choose your nursing home!
250 I-6 with a 3 speed Saginaw and Borg Warner Overdrive...She's got overdrive!
Botietruck is offline   Reply With Quote
Old 11-06-2005, 12:37 PM   #2
70c10
67-72 Addict!
70c10's Avatar
Re: Carb/trans. linkage question PICS!!
You are missing a ball and stud for the kickdown cable. Not sure about that vac line.
Jim
1970 C/10 Fleetside w/Ghost Flames
Lowered 4.5" front and 4" rear (Raked)
355/350 Turbo w/shift kit
10" Redneck Performance Verter w/2500 stall
Hooker Super Comps part#2808-1
Performer RPM Air-Gap
12 Bolt w/3:73 gears- Eaton Posi
Comp Cams XE262 with 1.6 Crane Energizers, Road Demon 625 and Brodix IK 180 heads
70c10 is offline   Reply With Quote
Old 11-06-2005, 01:06 PM   #3
demi
demi's Avatar
demi is offline   Reply With Quote
Old 11-06-2005, 06:01 PM   #4
Botietruck
Botietruck's Avatar
I came up with the ball and stud but I just can't stretch that cable long enough to hook it to the stud. It's like it's about 1" too short. Any ideas?
Old 11-06-2005, 06:15 PM   #5
texascowboy593
texascowboy593's Avatar
where the kickdown cableis attached to the engine (bracket) the black housing on top there is a piece that prys up. use a screwdriver to pry it up. when it is up, you should be able to pull that cable out. Once its re-connected, have a helper press down the accelerator(with engine off!) for 2 seconds then push tab back down. Should be properly set then. Test drive it and if not right keep playing with it! youll get it right!
"The rays of light thru the Shiner Bock bottle make me wanna turn the key and put down the throttle...and get lost down 35" - Jason Boland
www.YouTube.com/user/593Films - Watch My Videos!
1977 Silverado K10
2014 Dodge Durango (Wife-mobile)
2008 Dodge Ram Lone Star Edition (Daily driver)
texascowboy593 is offline   Reply With Quote
Old 11-10-2005, 10:07 PM   #6
Botietruck
Botietruck's Avatar
I hate to sound like an idiot,but I tried adjusting the cable to connect to the ball stud and it will not give me enough length. I pried the clip up and the cable released, but it still will not pull out far enough to connect. Can someone shoot me a pic of one connected, and if anyone has any other ideas, I'm all ears.
Thanks!
Bob
Old 11-11-2005, 02:14 AM   #7
Cat Fuzz
My son, my joy.
Cat Fuzz's Avatar
It's not supposed to be a ball stud for the kick-down. Its more of a post with a groove cut around it. It looks like a PO swapped carbs and didn't bother trying to match up the linkage. Usually you have to loosen the kick-down cable bracket or loosen the carb in order to slipt the end over the post on the carb. Thats so it doesn't slip off while driving.
'69 Chevy 3/4 ton, 327cid, Carter AFB, Edelbrock intake, HEI, TH400.
Founding member of the No Money To Spend On My Truck Club.
When your at Home Depot, you WISH you had gotten an 8 foot bed!
Cat Fuzz is offline   Reply With Quote
Old 11-11-2005, 08:24 AM   #8
mrein3
mrein3's Avatar
I think you have a 2bbl. kick-down bracket and a 4bbl. carb.
When I built my 383 it replaced a functioning 2bbl. carb/th350 kick-down setup. I put an edelbrock 4bbl carb on the new engine. There was no way that 2bbl kick-down bracket holder was going to work. I bought an aftermarket (edelbrock) adjustable (universal) bracket holder.
You can either go that route or find a 4bbl bracket in the yard.
The cables are the same 2 or 4 bbl.
'70 cab, '71 chassis, 383, TH350, NP205.
'71 Malibu convertible
'72 Malibu hard top
Center City, MN
mrein3 is offline   Reply With Quote
