11-06-2005, 02:47 PM | #1 |
Eaton info
I need some part #'s for the hub bearings and seals for my brothers Eaton.I've tryed going to the parts store with the old #'s that are on the bearings and they are and won't try to look they up.I also was wondering if 9/16" studs will go right into the same hole I took the 1/2" out of.I knew at one time but I've forgotten.
01 2500 Duramax,6spd,4x4,Not stock. Estimated 550rwhp/1100rwfp on fuel only. 03 3500 Duramax,6spd,4x4,Pac-Brake,not stock Estimated 500rwhp/1000rwfp fuel only 67 K10 in many pieces Little Brothers truck 67 K20 Cummins 12V/NV4500/205, D60/Eaton w/ Detroit,37" Xterrains,crossover steering, Future plans,Twins and lots of fuel. |
11-06-2005, 02:57 PM | #2 |
One of the First
Re: Eaton info
What kind of rear end is it? HO52 or HO72. Got any pictures? I have the bearing and seal numbers (NAPA) wrote down somewhere.
11-06-2005, 03:03 PM | #3 |
Re: Eaton info
It's a h072 3rd w/ Detroit and load bolt,h072 70"wsm housing,and h052 63" hubs. They all look the same,except for the one I shaved for more ground clearance .
11-06-2005, 03:19 PM | #4 |
Re: Eaton info
I agree, Napa should be able to help.
11-06-2005, 03:48 PM | #5 |
Re: Eaton info
Napa is where I went.Our local store sucks.
11-06-2005, 04:40 PM | #6 |
Re: Eaton info
I've heard you can also get stuff for these axles at carquest, but napa is probably cheaper.
RJD 1984 Chevrolet C30 welding truck 454/SM465 1977 GMC C15 pickup 350/TH350 1970 Chevrolet C20 pickup 350/TH400 1970 Chevrolet K20 Suburban 454/TH350 1969 GMC 8500 478M V6/5 spd winch truck |
11-06-2005, 04:51 PM | #7 |
One of the First
Re: Eaton info
Alright, I'm not at home to verify but, I had these parts boxes in my truck.
In the brake hub there is 2 sets of bearings and one seal. Seal # 28426 (NAPA) I'm not sure if this is the front wheel bearings or not. I belive its the rear . Bearing & Race # 362-A and 368-A / KB-116302 (NAPA) Bearing & Race # 382 and 388 / KD- 11786Y (NAPA) Hope this gets it done! |
11-06-2005, 05:55 PM | #8 |
Re: Eaton info
Thanks,I'll try it.What about the studs?
01 2500 Duramax,6spd,4x4,Not stock. Estimated 550rwhp/1100rwfp on fuel only. 03 3500 Duramax,6spd,4x4,Pac-Brake,not stock Estimated 500rwhp/1000rwfp fuel only 67 K10 in many pieces Little Brothers truck 67 K20 Cummins 12V/NV4500/205, D60/Eaton w/ Detroit,37" Xterrains,crossover steering, Future plans,Twins and lots of fuel. Last edited by 1967k30; 11-06-2005 at 05:56 PM. |
11-06-2005, 06:16 PM | #9 |
One of the First
Re: Eaton info
LMC Catalog!!! Pull one and match it at the parts store, not sure myself.
11-11-2005, 11:40 PM | #10 |
Re: Eaton info
Just wanted to post up some P.N.'s.The larger bearing and race is NAPA # KD11786-Y,the smaller one is KB11630-Z or 2 I can't read the writing{they wrote it down,didn't have in stock},and the seal is 28426. The large set was $85.05 for the pair and the seals were $15.16 for the pair.They are sure high priced but they are avaliable.I also asked about carrier bearings and such for Eatons and they said they could get them.I hope this helps someone else.
01 2500 Duramax,6spd,4x4,Not stock. Estimated 550rwhp/1100rwfp on fuel only. 03 3500 Duramax,6spd,4x4,Pac-Brake,not stock Estimated 500rwhp/1000rwfp fuel only 67 K10 in many pieces Little Brothers truck 67 K20 Cummins 12V/NV4500/205, D60/Eaton w/ Detroit,37" Xterrains,crossover steering, Future plans,Twins and lots of fuel. Last edited by 1967k30; 11-11-2005 at 11:41 PM. |
