![]() ![]() ![]() ![]() how many screws are there?............how do you get ![]()
TIM ![]() '71 CUSTOM C-10 torch red ,350 roller GM crate,3.73 GEARS, REAR 4"DROP SPRING, FRONT 2.5" DROP SPINDLE-1.5"lower spring, FRONT=17x8(4.5bs) W/265-60-17, BACK=17x9.5 (5bs)W/285-60-17, Vintage Air Sure Fit AC------NEVER ENDING PROJECT!! |
its all about the +6 inches
Re: dash pad replacement
Actual screws..4
however, on the back side (under dash) there are 6 or so nuts. 3/8 head if memory serves, but it's been a couple years. If you have A/C, it'll be a real PITA. Inst panel removal and glove box liner removal makes it 10 times easier. |
Yeah, you need to use a little hand driver and reach way up behind the dash and feel for those little buggers. There were 6 of them on mine if memory serves. One right behind the center of the glovebox that required the glovebox liner to be removed.
1971 Chevy C10 Shortbed Stepside, 307v8 3-on-the-tree |
Its the inside corner edge ones that drive me nuts trying to get too...the one above the radio aint so easy to get either. I used to have a little 1/4 inch drive flex shaft driver that I put the socket on..that worked good.
Senior active founding member. 70 3/4 ton GMC Suburban 4x4 250/4 spd. 71 1/2 ton Suburban Chevy 4x4, 350/350 72 Chev 1 ton tow truck 402BB w/Holmes 440 wrecker on propane 2005 FLSTSCI Harley Springer 85 FXSB Harley Lowrider 72 Triumph 650 Bonneville 5spd "Poor people don't have hobbies" Quote from wife. |
pita 4 sure!
Just lookn to buy a new one! What are your plans.
1968 Chevy C10 307 3ott fleetside 1967 Chevy C/10 V8, 3spd, fleetside lwb.Sold 1967 Chev C/10 step, 383, M21. SOLD |
i have one that i bought a year ago at the lowes autofair........i need to install it .........the wife questioning all my parts, and why do i buy them if i don,t install them.......but she do'nt understand .......you start taking the truck apart to do on thing and you wind up find more that needs to be done -----------before you can get back to the original thing you were doing..............that is the way it goes for me!!!!!!!!
